Results 1 to 12 of 12
  1. I do the following in Colab:
    !git clone -qqq https://github.com/nu774/mp4fpsmod.git > /dev/null
    !sudo apt-get update -y -qqq --fix-missing && apt-get install -y -qqq autoconf > /dev/null
    !cd mp4fpsmod/ && ./bootstrap.sh && ./configure && make && strip mp4fpsmod && make install
    And see the error:
    Running autoreconf...
    autoreconf: Entering directory `.'
    autoreconf: configure.ac: not using Gettext
    autoreconf: running: aclocal --force -I m4
    autoreconf: configure.ac: tracing
    autoreconf: configure.ac: adding subdirectory mp4v2 to autoreconf
    autoreconf: Entering directory `mp4v2'
    autoreconf: configure.ac: creating directory autoaux
    autoreconf: configure.ac: not using Libtool
    autoreconf: running: /usr/bin/autoconf --force
    configure.ac:83: error: possibly undefined macro: AC_LIBTOOL_WIN32_DLL
          If this token and others are legitimate, please use m4_pattern_allow.
          See the Autoconf documentation.
    autoreconf: /usr/bin/autoconf failed with exit status: 1
    Do you know what is wrong?
  2. october262 it does not work
    Feb 2006
    what linux version do you have ??
    is everything up to date ??
  4. I use Linux 4.19.104+ x86_64 Ubuntu 18.04.3 LTS in Colab
  5. this does not work also
    Feb 2006
  7. I don't know what he did. If you understand write the steps here.
  8. I managed to fix this error.
