I've recently tackled the task of restoring all of my VOB music video files so they look acceptable on high resolution screens.
However, its seems in nearly every telecined VOB I tackle, tfm().tdecimate() or even tfm().tdecimate(cycle=5) will always leave annoying duplicates in parts of the video. Sometimes there are so many that motion is actually smoother if I leave it undecimated. Or some cases, a cross-fade will have duplicates on one scene but not on the other.
Am I missing something really simple?
You have to look at each video, before doing IVTC, to make sure you understand the cadence. TFM is a pretty good field matcher, but it sometimes needs to be tweaked, and TDecimate most definitely needs to have the Cycle/CycleR parameters adjusted for some videos.
What method do you use to determine whether there are duplicates? Remember, you often need to first deconstruct the video into fields, using a non-blended Bob or a Separatefields(), so that you truly understand the decimation pattern. Looking at the video by simply viewing frames will not show you what you need to know. -
An untouched VOB or M2V sample from a DVD might help. One that shows the problem after a simple IVTC (but without the actual IVTC).
Music videos often have shots sped up or slowed down to sync the video to the music. This is typically done after the film has been telecined (ie, as interlaced video). So you end up with duplicate frames (when shots are slowed) or missing frames (when shots are sped up).;
Interpolate duplicates in hybrid video?
By embis2003 in forum RestorationReplies: 5Last Post: 22nd Mar 2020, 11:39 -
Video being show as duplicates
By Jezza in forum Newbie / General discussionsReplies: 6Last Post: 30th Dec 2019, 05:05 -
Duplicates Frames. Cause and means?
By nji9nji9 in forum RestorationReplies: 51Last Post: 15th Oct 2019, 12:21 -
Create mp3 duplicates of all mp4-files in a folder using ffmpeg
By DennisO in forum Video ConversionReplies: 29Last Post: 23rd Nov 2018, 06:37 -
How to ignore specific duplicates in multidecimate
By chummy02 in forum Newbie / General discussionsReplies: 8Last Post: 11th Jul 2017, 08:43
