  1. I'm new to vsdc... I'm wondering if there is a way to move multiple scene objects together so that their position relative to each other does not change. When I highlight them in the timeline and drag them to move they change relative positions slightly and this screws up the audio/video syncing
  2. Hi,
    The only solution I had found to solve this issue is to use "Convert to sprite" option on a group of block I want to move. You can still edit single blocks "inside" sprite
