I got a old and now it only flashes 3 red lights on the front panel, one power light and one rec light and the light to the rec light left and the fan moves a little, only very very very slow. I tried to pull out the fuse and use a metal to check but the result was the same. The front panel to the channels is black.
Results 1 to 9 of 9
have you tried doing a factory reset on both the machine and the HDD ??
I can't get it to start up. Probably not the hard drive that is the problem. The display is black. Only 3 red lights flashing.
Samsung DTB-P770V
By OldSchool297 in forum DVB / IPTVReplies: 2Last Post: 2nd Oct 2023, 00:01 -
problem to vcr samsung sv-a80g
By poya68 in forum Capturing and VCRReplies: 0Last Post: 7th Nov 2018, 08:57 -
Samsung DVD R 155 recorder not loading disc problem
By PJNH in forum DVD & Blu-ray RecordersReplies: 3Last Post: 1st Jul 2017, 21:07 -
Experiencing a big problem with my Samsung Blu Ray burner
By slaughteredlamb in forum DVD & Blu-ray WritersReplies: 1Last Post: 12th Apr 2017, 22:42 -
Samsung writer won't reinstall, not supported by Samsung
By blacktooth in forum DVD & Blu-ray WritersReplies: 4Last Post: 11th Jan 2017, 23:47
