Results 1 to 9 of 9
  1. Two different capture methods are apparently producing different DAR's: 4:3 for DV via firewire and 3:2 for Lagarith via s-video.
    Before buying a capture card, I experimented with capturing DV via firewire from a Sony DCR-TRV350. MediaInfo shows the following:
    Video
    Format : DV
    Commercial name : DVCPRO
    Codec ID : dvsd
    Codec ID/Hint : Sony
    Duration : 3 min 55 s
    Bit rate mode : Constant
    Bit rate : 24.4 Mb/s
    Width : 720 pixels
    Height : 480 pixels
    Display aspect ratio : 4:3
    Frame rate mode : Constant
    Frame rate : 29.970 (30000/1001) FPS
    Original frame rate : 29.970 (29970/1000) FPS
    Standard : NTSC
    Color space : YUV
    Chroma subsampling : 4:1:1
    Bit depth : 8 bits
    Scan type : Interlaced
    Scan order : Bottom Field First
    Compression mode : Lossy
    Bits/(Pixel*Frame) : 2.357
    Stream size : 807 MiB (94%)
    I just received and installed a Magewell Capture Pro HDMI, which produces the following file characteristics:
    Video
    Format : Lagarith
    Codec ID : LAGS
    Duration : 32 s 566 ms
    Bit rate : 46.2 Mb/s
    Width : 720 pixels
    Height : 486 pixels
    Display aspect ratio : 3:2
    Standard : NTSC
    Color space : YUV
    Chroma subsampling : 4:2:2
    Bit depth : 8 bits
    Bits/(Pixel*Frame) : 4.404
    Stream size : 179 MiB (94%)
    I have tried various settings, but the output file always shows 3:2 DAR. Also, there is no indication the output file is interlaced.
    Do these MediaInfo outputs indicate anything wrong?
    By the way, the 486 vertical resolution was an experiment... I assume I should be using 720 x 480.
  2. Member DB83's Avatar
    Jul 2007
    If memory serves, DV has a proper aspect-ratio flag so your 720*480 displays at 4:3.
    Lagarith uses square-pixels so 720*480 is pure 3:2 (do the maths)
  3. In other words, with Lagarith (and most other lossless codecs) it's up to you to keep track of the display aspect ratio and sample aspect ratio.
  4. OK - Thanks, so I'm ok on calculated (Lag) vs flagged (DV) DAR. It's up to me to output proper DAR in the final video.
    Any way to verify the saved file remains interlaced? I don't see the distinct combing I saw with Windows Media Encoder after capturing the DV videos.
  5. I found this approach for checking interlacing, but syntax must be wrong... Returns "/dev/null: No such file or directory"
    ffmpeg -filter:v idet -frames:v 100 -an -f rawvideo -y /dev/null -i [filename]
  6. That's linux syntax. For windows you can use:
    ffmpeg -i filename.avi -filter:v idet -frames:v 100 -an -f null -
    Or open your video in VirtualDub2 and look at it in the input pane. You should see comb artifacts if it's interlaced.
    Thanks!! As I suspected (based on viewing), the s-video captured file is not interlaced:
    [Parsed_idet_0 @ 0000023ad9a7cf00] Single frame detection: TFF: 0 BFF: 0 Progressive: 100 Undetermined: 1
    [Parsed_idet_0 @ 0000023ad9a7cf00] Multi frame detection: TFF: 0 BFF: 0 Progressive: 100 Undetermined: 1
    Now, I've just got to figure out why...
  8. I'm going to start a new thread, since I've deviated from the original DAR question. Thanks for the help!
  9. Keep in mind that that command only looks at the first 100 frames. If your video starts with a still shot the report may not be accurate.
