A while ago I downloaded some videos and decided to copy them to DVD. So I burnt them not as a DVD but as a file, so I could watch them on my laptop and supposedly other laptops as well? As before ejecting a statement would come up in the bottom right of the screen saying something along the lines
"It was finalising, so I could watch this DVD on other laptops." Well I tried watching a DVD today on another laptop and it would not recognise the disc! Is there anything I could do or are they now lost?
Results 1 to 10 of 10
what type of video files are they ?? does the DVD play on a regular DVD player.
If I read you correctly you have not created a dvd-video disk. So you can not play such a disk in a dvd-player.
What happens when you attempt to open the disk in Windows Explorer ? You should be able to see the files you put on the disk and by selecting one it should play as if the video was still on your hard disk. -
I have taken them mainly from YouTube. It goes into my downloads and from there I have the ability to burn them as a DVD, or as a DVD that supposedly can play on other computers. When finalised they are ejected. Hope this helps?
What software did you use to copy files to a DVD?
Ignore list: hello_hello, tried, TechLord, Snoopy329 -
I just inserted a disc and was taken to Files currently on the Disc (1). Then a blue oblong appears in the middle of the screen saying This app can't be opened There's a problem with Film & TV Contact your system administrator about repair or reinstalling. I'm using Lenovo ideapad 12cs-11iap model name 81a4
The software I used was on my hp computer 11AH005na -
You have to search the files in Windows Explorer, not to open them. Once found, copy them to your HD.
Connecting Laptop to Laptop through USB
By dfisher052 in forum Newbie / General discussionsReplies: 14Last Post: 10th Sep 2018, 05:23 -
DCP vs playing film through laptop at cinema
By kieranvyas in forum EditingReplies: 5Last Post: 14th Dec 2017, 23:58 -
DVD video color disappearing when playing VOB's, not when playing DVD
By lelegard in forum Video ConversionReplies: 6Last Post: 21st Aug 2016, 16:06 -
Composite digital signal into laptop: can't find signal stream on laptop!!
By herder in forum Capturing and VCRReplies: 19Last Post: 17th Jul 2016, 15:11 -
copy same software installation from laptop A to laptop B ?
By vhelp in forum ComputerReplies: 9Last Post: 7th Oct 2015, 13:21
