  1. Hi,
    I have gone through the forum and help documents before posting here.
    I have created a simple plugin using InvertNeg sample or very similar.
    This compiles fine using visual studio 2019 but the avs script will not load the plugin with the error message "x cannot be used as plugin for avisythn"
    I am using the AvsPmod to confirm that script is fine and that file works. Without the plugin using L-Smash all is good.
    I have initially thought perhaps using vs2019 is the issue but i have used the avisynth 3.5.1 [AviSynthPlus-3.5.1_20200402_vcredist.exe] which appears to support the latest ms version
    This is all 32 bit to ensure that is not the issue.
    I have attached the vs project with the lib and include in the zip
    any helpers or pointers would be greatly appreciated.
  2. I have resolved this issue attached a project
    here is a sample avs script:
    LoadPlugin("D:\testplugin\InvertNeg3.dll")
    clip = BlankClip().ConvertToYV12()
    return clip.InvertNeg3()
    Aug 2013
    Central Germany
    AviSynth+ development is currently active, mostly in the doom9 forum, there you can find the developers who may give you some general advice how to ensure compatibility.
