Results 1 to 11 of 11
    Apr 2020
    Turkey
    Hello everyone,
    I previously recorded some MP4 videos on my pc using HD Video Recorder. I tested and watch all of them after i recorded and they were all ok. But recently, i tried to watch some of them and saw that some of those videos has lost their sound on videos. Some of them still works well, but others play only visions and there is no sound. I have used Video Converter Ultimate of Wondershare to fix it but it did not help either. How can i fix that problem?
  2. post a short example of a video without audio here or post its MediaInfo.
    Apr 2020
    Turkey
    Hi, i uploaded a part of the video please find the attached mp4 video.
  4. There's no signal in your audio stream.
    Apr 2020
    Turkey
    Does that mean there is no solution for this issue?
    Mar 2008
    The audio in the file is a very low level white noise. That is all there is.
    Apr 2020
    Turkey
    So, can you help me fix it? I'm not familiar with technical issues on videos
  8. Originally Posted by kesis105 View Post
    It means there is no actual audio in this clip. You have to get the audio from somewhere else. You cannot fix it with what is there.
    Apr 2020
    Turkey
    Got it thanks everyone of you
  10. Yes, definitely no audio. You may have tested some of the clips after you recorded them, but you must not have tested this one because audio doesn't just suddenly disappear from a video clip.
  11. Just an FYI
    I had an issue a couple of years ago with ffmpeg not including the audio of some
    files when conveting to MP4 - somethig to watch for if your ffmpeg isn't recent.
    (No errors were flagged - I didnt find out until much later)
