There was 4 frames (24366,24367,24368,24369 frame) damaged in my video record (196420 frames in total). I extract damaged frames as .bmp with AvsPmod. And fixed with photoshop.
Tried many time, couldn't replace them .
Some tries without success:
------------------Code:#Source ... B=ImageSource("E:\Poem (1972)\GBR\Theatrical Cut\%03d.bmp", end=196420).ConvertToYV12 () ReplaceFramesSimple(last, B, mappings="[24366 24369]")
Any replies appreciated!Code:#Source ... B=ImageSource("E:\Poem (1972)\GBR\Theatrical Cut\000.bmp", end=196420).ConvertToYV12 () ReplaceFramesSimple(last, B, mappings="[24366 24369]")
What does "couldn't replace them" mean? The old frames didn't change? You see error messages?
RemapFrames has a tricky syntax. I tried this years ago on a clip that had frames out of sequence:
Code:BaseVid=last SourceVid=ImageSource("E:\Poem (1972)\GBR\Theatrical Cut\000.bmp",end=4,pixel_type="YV12") BaseClip=BaseVid BaseClip=BaseClip.RemapFrames(mappings=" [24366 24369] [0 3] ",SourceClip=SourceVid) return lastLast edited by LMotlow; 26th Apr 2020 at 00:07.
- My sister Ann's brother -
I do it a slightly different way, and a single frame at a time. Maybe you can modify the following snippet to make it replace all your frames at once:
Q=ImageSource("xxxxx.bmp",End=xxxxx).ConvertToYV12 ()
ReplaceFramesSimple(Last,Q,Mappings="xxxxx ")
xxxxx is the frame number to be replaced and xxxxx.bmp is the edited picture (named after its frame number). Q is used so as not to interfere with other letters used throughout the script.
And, as LMotlow wrote, always include the error messages that VDub gives you. -
I'm glad about responses, thanks!
Sorry for not being clear.
This thing made me angry.
All 4 scripts in below opening avspmod without error. But all of them has own problem:
All replaced frames are total black.
Code:B=ImageSource("E:\Poem (1972)\GBR\Theatrical Cut\%03d.bmp", end=196420).ConvertToYV12 () ReplaceFramesSimple(last, B, mappings="[24366 24369]")
All replaced only with 000.bmp:
Nothing changed, same bad frames here:Code:B=ImageSource("E:\Poem (1972)\GBR\Theatrical Cut\000.bmp", end=196420).ConvertToYV12 () ReplaceFramesSimple(last, B, mappings="[24366 24369]")
Only frame 22366 replaced with 000.bmp:Code:BaseVid=last SourceVid=ImageSource("E:\Poem (1972)\GBR\Theatrical Cut\000.bmp",end=4,pixel_type="YV12") BaseClip=BaseVid BaseClip=BaseClip.RemapFrames(mappings=" [24366 24369] [0 3] ",SourceClip=SourceVid) return last
Code:last=FFVideoSource("POEM.mkv") Q=ImageSource("000.bmp",End=24366).ConvertToYV12 () ReplaceFramesSimple(Last,Q,Mappings="24366") -
If the file names are 24366.bmp .....
If the filenames were 000.bmp.... It would beCode:orig=FFVideoSource("POEM.mkv") Q=ImageSource("%05d.bmp",start=24366, End=24370, fps=orig.framerate).ConvertToYV12() orig.trim(0,24365) + Q + orig.trim(24371,0)
If you converted to the BMP for photoshop using ConvertToRGB default settings, it would use Rec601 . Then ConvertToYV12() would be correct to "reverse" it. Normally 709 is used for "HD", but you didn't mention what you haveCode:Q=ImageSource("%03d.bmp",start=0, End=4, fps=orig.framerate).ConvertToYV12() -
