Hi. I'm trying to edit a concert video of my band. I use a separate audio track, and then two video tracks. When I edit the track, the tracks are all synchronised in the preview screen, but when I export the video one of the video tracks runs a little behind. Anything I can do about this?
It might help if you provided more information -
What editor you are using ?
How are the 2 videos arranged in the export video?
What export format and settings were used ? -
Hi! Thanks for your replies.
So, the streams all have the same length in this file. I cut them out of the footage of the entire concert, in which the audio stream and both camera streams all start at different moments during the concert.
The camera streams are an MTS file and an mp4 file, the audio comes from a wav file.
This is the info on the files I got from the export page:
Video track: 1/1
Width: 1280 pixels
Height: 720 pixels
Framerate: 30 fps
Bitrate: 884 kbps
Aspect: 1280:720
Codec: raw video
Duration: 02:56
Audio track: 1/1
Language: Track 1
Frequency: 44100 Hz
Channels: 2
Bitrate: 1411 kbps
Codec: PCM signed 16-bit little-endian
Duration: 02:56
I tried to export it into .avi. I will try export it to .mpg or .flv and see if this works better. -
Try to mux them with MkvToolNix to mkv, specifying 30 fps for the videostream. Convert the audio first to ac3 448 kbps or aac 256 kbps.
Not appear video virtualdub2 fast forward
By media in forum EditingReplies: 2Last Post: 10th Feb 2020, 02:12 -
Avisynth - Audio track longer than video track
By martanius in forum AudioReplies: 4Last Post: 18th May 2018, 02:13 -
How to change fast forward video format to standard speed video with voice
By Shah82 in forum RestorationReplies: 2Last Post: 11th Jan 2018, 10:04 -
Seeking/jumping forward/backward in a video
By [ss]vegeta in forum Software PlayingReplies: 8Last Post: 6th Aug 2017, 09:21 -
Problem with HDTV fast-forward through video
By snafubaby in forum Video ConversionReplies: 1Last Post: 15th Dec 2015, 02:47
