I have a friend that has a RDR-VX511. She has dubbed VHS videos to it. Unfortunately she does not have a remote for the unit and cannot finalize the discs. We have tried to finalize the DVDs on her computer via IMG Burn but it gives us the "I/O Error!" message when we try.
Can you suggest any way to finalize these discs so we can get them onto her PC for editing? I am also looking to find a remote for it.
Thanks ahead of time!
If we can find the original OEM remote for sale somewhere, we will. That is something else I am working on.
Ebay for remotes.
https://c.getsatisfaction.com/nero_eng/topics/finalize_dvd_r
If it's possible on a pc....
Otherwise, I've found no. If you dont finalize on the deck, no way on the pc. -
Its always better to finalize the disc on the machine that made it if at all possible. Unfortunately as many owners learn to their grief, you cannot be lax and sloppy about "losing the remote" because these machines are useless without them. The RDR-VX511 dates from 2005, normally it can be tough finding remotes for a unit that old but apparently it was popular enough that plenty of original remotes are floating around. While generic brand new knockoff remotes are available slightly cheaper than a good used original, I'd recommend going with the real deal because this model is apparently more picky about remotes than similar Sonys. Note if the recorder has ever been reprogrammed from the default remote code (3) to one of the alternates, you may need to move the little switch on the remote to one of the other code settings (1 or 2) before the recorder will respond to it. The correct remote model is Sony RMT-D224A, lots of clean examples currently available on eBay between $20 - $30:
https://www.ebay.com/sch/i.html?_from=R40&_trksid=p2386202.m570.l1313.TR1.TRC0.A0.H0.X...d224a&_sacat=0
If you need the instruction manual for details on finalizing, you can download it from Sony at this link:
https://www.sony.com/electronics/support/res/manuals/W000/W0009175M.pdf
ISObuster software is an alternative solution to extracting video from unfinalized discs, but be aware it can take quite some time with some discs and the "free" trial version will just go thru the motions but not actually extract the video until you pay $39.95 for a full license key. Amazing piece of software, well worth the money if you'll be using it a lot for other things as well, but in cases of "I lost the remote" its almost always better to buy another remote instead. If nothing else, it restores full functionality to the recorder (and your ability to sell the machine off when you don't need it any longer for at least what you spent on the remote).Last edited by orsetto; 25th Apr 2020 at 11:24.
Thank you for the excellent responses. I have passed this information onto the friend.
Why x264 "placebo" preset produce bigger file than "very slow"?
By aleaksunder in forum Video ConversionReplies: 21Last Post: 2nd Mar 2019, 08:25 -
What is the purpose of "Default" button in "Video" tab of XMedia Recode?
By MidnightUser in forum Newbie / General discussionsReplies: 1Last Post: 15th Jan 2016, 04:08 -
How i can encode audio of "REMUX" to "BluRay.720p.DTS" wit handbrake?
By VideoHelp4Ever in forum Blu-ray RippingReplies: 1Last Post: 2nd Jul 2015, 12:41 -
[SOLVED] "--ipratio" "--pbratio"+"--scenecut" "--minkeyint" / "--keyint
By Kdmeizk in forum Video ConversionReplies: 14Last Post: 21st Jun 2015, 08:21 -
VHS to DVD - Turning off on-screen "STEREO" warning on Sony SLV X811 VCR
By 2prfm.com in forum Capturing and VCRReplies: 6Last Post: 18th May 2015, 14:44
