Even though i was set to only get pm from mods and contacts i get them from others including spam. I have now had to disable pm
Methinks must amend your privacy profile since if 'Contacts' is set for 'Everyone' it may override your PM settings.
Have you reported the PM?
But it must be SPAM with some nonsense spam links.... -
How can somebody receive a PM in here unless it's by another (identifiable) member ?
In that case report the member(s) to the Admin -
^^ PMs can be filtered. As the OP stated. Yet I also replied that there is another privacy setting that the OP should look at.
A common courtesy of acknowledging the reply, even if it is not the solution, would not go amiss.Last edited by DB83; 27th Apr 2020 at 03:26.
Problems Demuxing, Remuxing and Encoding AVIs. Also MeGUI problems.
By VideoFanatic in forum RestorationReplies: 1Last Post: 10th Feb 2016, 02:30
