Hello. I haven't been a real programmer for 35 years or more (think PDPs and VAXs and real core memory). On a good day I can fiddle with simple bash scripts and a bit of simple python.
I'm stuck and am seeking your advice on building ffmpeg with the latest OpenCL-ICD-Loader so that ffmpeg can use OpenCL and thus access nvidia's FAST GPU-accelerated filters such as "unsharp_opencl".
For a while I've been cross-compiling ffmpeg.exe with OpenCL for use on Win10x64 (using a derivative of deadsix27's work on githib). Here https://github.com/hydra3333/h3333_python_cross_compile_script_v100
Deadsix's cross-compile build system uses a Python3 script to read sets of parameters and manage the build processes for a range of (upstream source) dependencies and then builds ffmpeg.exe. It appears as if it may be similar "in outcome terms" to Zeranoe's thing.
It
* runs in a VM under Ubuntu 18.04.3
* installs mingw64, builds gcc for producing win10x64 binaries
* downloads and cross-compiles dependencies
* cross-compiles and links ffmpeg.exe
However circa 2020.04.20 commits to upstream ICD loader source broke cross-compilation compatibility, and they as yet haven't any suggestions on how to address the issue ...
The error is this file windows.management.deployment.h is a new dependency not found within mingw64 and I can't seem to find a source for it (if indeed that'd fix it).
Code:[14:17:54][DEBUG] Running 'ninja -j 4 ' in '/home/u/Desktop/_working/workdir/x86_64/OpenCL-ICD-Loader_git' [1/4] Building CXX object CMakeFiles/OpenCL.dir/loader/windows/icd_windows_apppackage.cpp.obj FAILED: CMakeFiles/OpenCL.dir/loader/windows/icd_windows_apppackage.cpp.obj /home/u/Desktop/_working/workdir/toolchain/x86_64-w64-mingw32/bin/x86_64-w64-mingw32-g++ --sysroot=/home/u/Desktop/_working/workdir/toolchain/x86_64-w64-mingw32 -DCL_TARGET_OPENCL_VERSION=220 -DOpenCL_EXPORTS -Iinc -I. -Iloader -O3 -fstack-protector-all -D_FORTIFY_SOURCE=2 -O3 -DNDEBUG -MD -MT CMakeFiles/OpenCL.dir/loader/windows/icd_windows_apppackage.cpp.obj -MF CMakeFiles/OpenCL.dir/loader/windows/icd_windows_apppackage.cpp.obj.d -o CMakeFiles/OpenCL.dir/loader/windows/icd_windows_apppackage.cpp.obj -c loader/windows/icd_windows_apppackage.cpp loader/windows/icd_windows_apppackage.cpp:27:10: fatal error: windows.management.deployment.h: No such file or directory 27 | #include <windows.management.deployment.h> | ^~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ compilation terminated. [2/4] Building C object CMakeFiles/OpenCL.dir/loader/windows/icd_windows_envvars.c.obj [3/4] Building C object CMakeFiles/OpenCL.dir/loader/windows/icd_windows_hkr.c.obj FAILED: CMakeFiles/OpenCL.dir/loader/windows/icd_windows_hkr.c.obj /home/u/Desktop/_working/workdir/toolchain/x86_64-w64-mingw32/bin/x86_64-w64-mingw32-gcc --sysroot=/home/u/Desktop/_working/workdir/toolchain/x86_64-w64-mingw32 -DCL_TARGET_OPENCL_VERSION=220 -DOpenCL_EXPORTS -Iinc -I. -Iloader -O3 -fstack-protector-all -D_FORTIFY_SOURCE=2 -O3 -DNDEBUG -MD -MT CMakeFiles/OpenCL.dir/loader/windows/icd_windows_hkr.c.obj -MF CMakeFiles/OpenCL.dir/loader/windows/icd_windows_hkr.c.obj.d -o CMakeFiles/OpenCL.dir/loader/windows/icd_windows_hkr.c.obj -c loader/windows/icd_windows_hkr.c loader/windows/icd_windows_hkr.c: In function 'khrIcdOsVendorsEnumerateHKR': loader/windows/icd_windows_hkr.c:217:21: error: 'CM_GETIDLIST_FILTER_CLASS' undeclared (first use in this function); did you mean 'CM_GETIDLIST_FILTER_BITS'? 217 | ULONG ulFlags = CM_GETIDLIST_FILTER_CLASS | | ^~~~~~~~~~~~~~~~~~~~~~~~~ | CM_GETIDLIST_FILTER_BITS loader/windows/icd_windows_hkr.c:217:21: note: each undeclared identifier is reported only once for each function it appears in loader/windows/icd_windows_hkr.c:218:21: error: 'CM_GETIDLIST_FILTER_PRESENT' undeclared (first use in this function); did you mean 'CM_GETIDLIST_FILTER_BITS'? 218 | CM_GETIDLIST_FILTER_PRESENT; | ^~~~~~~~~~~~~~~~~~~~~~~~~~~ | CM_GETIDLIST_FILTER_BITS loader/windows/icd_windows_hkr.c:343:22: error: 'DEVPKEY_Device_ClassGuid' undeclared (first use in this function) 343 | &DEVPKEY_Device_ClassGuid, | ^~~~~~~~~~~~~~~~~~~~~~~~ ninja: build stopped: subcommand failed.
It builds with OpenCL capability using these parameters.
Your kind suggestions and advice would be most appreciated.Code:{ 'repo_type' : 'git', 'url' : 'https://github.com/KhronosGroup/OpenCL-ICD-Loader.git', 'depth_git' : 0, 'branch' : '6d0b214b9cc303cdb0b05b3c0dc9afb0c39998c5', # 2020.04.20 icd_loader broke upstream 'needs_make_install' : False, 'conf_system' : 'cmake', 'configure_options': '. {cmake_prefix_options} -DCMAKE_INSTALL_PREFIX={target_prefix} -DCMAKE_BUILD_TYPE=Release -DBUILD_SHARED_LIBS=ON -DBUILD_TESTING=OFF -DOPENCL_ICD_LOADER_REQUIRE_WDK=OFF', # 2019.12.13 'run_post_build' : [ 'cp -vf "libOpenCL.dll.a" "{target_prefix}/lib/libOpenCL.dll.a"', 'cp -vf "libOpenCL.dll.a" "{target_prefix}/lib/libOpenCL.a"', 'if [ ! -f "already_ran_make_install" ] ; then touch already_ran_make_install ; fi', ], 'patches' : [ ('opencl/0001-OpenCL-git-prefix.patch', '-p1'), ('opencl/0002-OpenCL-git-header.patch', '-p1'), ], 'run_post_regexreplace' : [ 'sed -i.bak \'s/Windows.h/windows.h/\' ./loader/windows/icd_windows_envvars.c', ], 'depends_on' : [ 'opencl_headers' ], '_info' : { 'version' : 'git (master)', 'fancy_name' : 'OpenCL-ICD-Loader' }, }
They've done something upstream with a new configure switch, which allows export of symbols only and thus bypasses the issue.
Good oh.
ffmpeg.exe with 33bit patch
By gre2gor in forum ProgrammingReplies: 0Last Post: 11th Dec 2019, 09:41 -
what would xp supporting ffmpeg.exe be? and win 10
By sommers in forum Newbie / General discussionsReplies: 4Last Post: 15th Oct 2018, 09:30 -
ffmpeg.exe -i %1 -r 1 xxx-%06d.JPG what is better quality capture command?
By sommers in forum Newbie / General discussionsReplies: 4Last Post: 5th Jun 2017, 13:06 -
ffmpeg.exe keeps crashing
By Randomletters in forum SVCD2DVD & VOB2MPGReplies: 14Last Post: 17th Jan 2017, 15:04 -
what is the latest ffmpeg input driver 64 bit for virtualdub-64bit?
By marcorocchini in forum Newbie / General discussionsReplies: 2Last Post: 23rd Aug 2015, 17:24
