Hey guys. I have a rare 25 disc boxset of an old TV animated series. I would like to archive them that way I can enjoy my copies and let the originals sit as the collector's item they were made to be. I was considering that since they are in standard definition, I would like to just author them onto blu ray discs. What is the recommended format and bitrate to get these from DVD to hard drive without any quality loss before compiling them onto the blu rays?
Results 1 to 13 of 13
- My sister Ann's brother
I know that it is not possible to author a BD with mkv, but it is far more convenient to put the mkv files onto an USB drive and plug it into the TV and play it with integrated Media Player or play it on a dedicated HTPC or whatever. I pointed out a simpler and better solution than to author a Blu-ray Disc.
I don't know where this fascination with klutzy TV media players comes from, or why USB drives are so elevated as storage media. You would backup up that USB drive to another one. It's going to take a very long time to get that collection as separate videos onto a USB drive and then to search for individual clips. Why go through all that when AnyAVCHD can convert DVD to BluRay format with no reencoding. BluRay does come in standard definition. For better authoring I 'd go with something like TMPGenc Authoring Works.
My concern is: Why BluRay? If anyone is thinking that DVD upsampled to HD BluRay for high defintiion will look great, they're going to be sadly disappointed -- the original DVD will look much better than the resulting re-processed BluRay. Standard definiton BluRay is part of the BluRay spec and can be had by changing containers from VOB to BluRay m2ts without re-encoding, especially since MPEG is valid for BluRay. Of course the result would have to be re-authored to new menus.- My sister Ann's brother -
I don't use built in TV media players, I have a self built HTPC, but for most users it will be enough. USB drives can be better in the the long run then self burnt stuff. But don't use cheap USB drives, these will fail.
I have some Corsair Flash Voyager GTX and also some Sandisk Extreme, and these are all fine and very fast. For many years now.
Get a 2 HDDs for Archival and a good quality USB Stick for using and you are fine.
I presented a method which works like a charm, is free except of HDDs and USB drive and you have a backup if really somehing will break, just get another HDD and copy it again on it. I use WD HDDs which are at least 7 years old and are working fine. But I have also bought some Seagate some years ago and can not say anything against these drives, despite I had one HDD with an error in the firmware (about 2007) which led to death and data was gone, but hey that's what a backup is for.
I don't want to argue, so I am out. It will take some till I come back here for giving "videohelp", ... -
First, find out how the episodes are encoded on the DVDs. Depending on how the episodes are encoded for DVD it may be possible to author a Blu-ray disc without re-encoding the episodes at all. There is some overlap between the Blu-ray standard and the DVD standard. Blu-ray includes some SD interlaced resolutions (720×480 29.97 frames interlaced / 59.94 fields (4:3/16:9) and 720×576 25 frames interlaced / 50 fields (4:3/16:9)) as well as MPEG-2 video, plus AC3 audio and LPCM audio. You will need more Blu-ray discs to hold MPEG-2 video but no quality will be lost and it saves some time.
You will still have to create new menus for the Blu-ray copies because the DVD menus use different technology. If the DVDs include selectable subtitles, I'm not sure how to convert them for Blu-ray.
[Edit]I forgot to suggest some free DVD decrypters to remove copy protection and copy the DVD files and folders to your HDD so you can examine the video and audio. DVDFab HD Decrypter, DVD Decrypter, and DVD43 are older, free software that still works for copying many DVDs to a Windows PC hardware.Last edited by usually_quiet; 24th Apr 2020 at 11:54.
Ignore list: hello_hello, tried, TechLord, Snoopy329 -
Because people nowadays almost do not touch optical discs anymore. They use phones, laptops of some sort with no optical discs and if they do not use PlayStation or XBox they are touching discs almost by an accident.
Backing up to to MKV or VIDEO_TS is just copying a files, also copying those to the other hardisks is fast and simple. Then handling them later an mass is a win. How is it more difficult? -
try dvdfab dvd to blu-ray converter - https://www.dvdfab.cn/dvd-to-blu-ray-converter.htm
Fortunately I've saved my eyesight from the boredom and annoyance of watching movies being discolored by laptop screens and idiotically reduced and reencoded into distortion on iphones. It's a sad day for video indeed. No wonder this forum is so infamous for "help" in lowering quality standards. Count me out.
Without thinking too hard.
A dvd decrypter like anydvd.
Mpg2cut2 to rewrap vob files on disc into mpeg-2 mpg files.
https://tmpgenc.pegasys-inc.com/en/product/taw6.html
Tmpgenc with Smart Encoder to avoid reencoding the mpg files when mastering blurays.
Tons of alternatives to each step. -
TMPGEnc Authoring Works 6, which you suggested, appears to accept MKV files as input (with some limitations). This is from the table listing input formats at https://tmpgenc.pegasys-inc.com/en/product/taw6_spec.html:
What is "AnyAVCHD" and where does someone find it? I didn't find it in VH's software section and my search engine only found something called "Any AVCHD Converter" in the Mac App Store which converts video to formats that are playable with an iPad.MKV (.mkv) *Limited to video and audio stream formats normally readable through the MPEG Reader.Ignore list: hello_hello, tried, TechLord, Snoopy329 -
You asked why folks would use media players that use USB connections (as oppose optical disks). I answered. That was about not using optical discs. That could mean using anything else available for streaming (player, DLNA device, casting ...). I was not recommending using laptop or phone to watch video. It is about not having DVD players or BD players handy or not having them at all or not trying " to burn a disk" which sounds to them like "burning witches" maybe. It is as it is. Sure young's now tend to use their ear buds and watching something in a corner somewhere, but that is something else.
Rip Blu-ray and UHD Movie
By Roosvelt in forum Blu-ray RippingReplies: 39Last Post: 18th Nov 2019, 15:12 -
Crop and Pad a Blu Ray rip?
By jcwillia1 in forum Blu-ray RippingReplies: 4Last Post: 31st May 2018, 08:02 -
How to rip blu-ray movies?
By jatt in forum Newbie / General discussionsReplies: 6Last Post: 19th Apr 2018, 04:12 -
rip my Ultra HD Blu Ray discs is that possible?
By thanosazlin in forum Blu-ray RippingReplies: 50Last Post: 4th Aug 2017, 15:45 -
Blu-ray remux to mkv shows audio dropouts.
By Mazuda To Yo Da in forum Newbie / General discussionsReplies: 3Last Post: 14th May 2016, 15:48
