I've been using virtual dub lately for capturing to AVI, then converting to SVCD with avi2svcd (or tmpgenc if the avi has commercials). It seems that when I use either Huffy or norecompression that I still loose frames (even at 320x240 with huffy selected). I'm wondering if I can add more video compression options so that I dont' loose frames and I can capture at higher quality and select my bitrate when I capture. here is a picture of what my compression options look like http://nfl2k2.150m.com/vdub.jpg . any help?
Windows 2000
1.0 Gighz Athlon
Radeon 64mb DDR, VIVO
640mb sdram
This is a question regarding the video formating options in Virtual:
I'm trying to capture miniDV from a Sony TRV10 to avi on my PC. In the Video format there are no options to select YU2U or others. The only option is dvsd. Also, if I try to change the video formating in the Customs format, I get an eror message "410" and a message that the format isn't supported. Disd I get a bad download of Virtual (I downloaded it twicw" or is this camcorder not supported by virtual? -
Basically it looks like you need to simply install more codecs. MJEG is a nice one to use. With your computer, you could probably even capture directly to a Mpeg4/DivX format. With an Athlon 700 I can capture directly to DivX using the fastest compression to 360x360 (up to 6000 kbps). With your faster processor you may even be able to get SVCD quality or more (I start dropping frames like mad with DivX as soon as I make the vertical resolution over 360). Basically, you need to find codecs and install them.Originally Posted by nfl2k2
I really have to recommend an MJEG codec though.
for the PicVideo Mjeg, go to http://www.jpg.com/video/mjpeg.htm I believe it puts a watermark on your files until you register it.
Morgan Multimedia goes for the trial version approach. They're at www.morgan-multimedia.com
There's lots of cool codecs on this page:
http://freepctech.com/pc/002/files011.shtml
You should be able to add quite a few to your selection. I'd avoid DivX 5 as some versions have spyware that anonymously reports things back to the company that made it. Go for DivX 4.12 if you are going to use a DivX codec. I love the Mjeg ones though. -
If you visit
http://www.microsoft.com/downloads/release.asp?ReleaseID=31921&area=search&ordinal=2
and download and install the wmpcdcs8.exe package (717KB) then you'll have all the latest Direct Show filters and MPG4 codecs 1, 2 & 3 (plus other legacy codecs).
With my Duron 900 & 512 MB RAM (W2K) i capture VHS with the MPG4 V2 codec - bitrates of about 1500Kb/s and am happy with the results.
Codec package
http://download.microsoft.com/download/winmediatech40/Install/8.0/WIN98Me/EN-US/wmpcdcs8.exe
(Watch out for word wrap with the links).
Martin.
Video in Virtual dub out of sync
By lituvis in forum Video ConversionReplies: 0Last Post: 7th Mar 2012, 10:56 -
Windows 7, Virtual Dub (any Version), BlackMagic Intensity Pro = No Capture
By Digital-Overload in forum Capturing and VCRReplies: 2Last Post: 22nd May 2011, 11:57 -
problem with compression using virtual dub
By jpez1 in forum Video ConversionReplies: 4Last Post: 3rd Aug 2010, 14:24 -
no options in audio compression for virtual dub
By jonbaker in forum AudioReplies: 9Last Post: 14th Feb 2010, 20:00 -
Virtual Dub Deshaker - how to use in Batch mode (Dubman) without loosing 30
By Speed Demon in forum RestorationReplies: 3Last Post: 13th Jan 2008, 22:24
