Hi,
I have a bunch of avi files, and I know some of them have little breaks, they're missing a second or jumping a few frames. How can I analyse each file so that I know the ones that have issues, and where in the video the breaks are?
I've tried Virtualdub with a file I knew had issues, and it didn't find any errors
Thank you.
The only way you can check is by manually viewing the video,there's no program that will tell unless they are actual breaks in the file that cause playing issues.
I'm not sure this is your case ... see
https://forum.videohelp.com/threads/381639-How-can-I-find-corrupted-frames-in-my-encode
especially ..
https://forum.videohelp.com/threads/381679-Finding-individual-bad-frames-in-video-and-...ir#post2470118責任者-MDX
tool to check video files for freezes? (downloaded with letmeatit)
By schmutzbrust in forum Newbie / General discussionsReplies: 12Last Post: 8th May 2020, 18:47 -
AVI Files Smaller Than WMV Files
By tutorpros in forum Newbie / General discussionsReplies: 51Last Post: 23rd Dec 2017, 18:44 -
How do I check if my wav files are loseless?
By jacktherabbit in forum AudioReplies: 2Last Post: 29th Sep 2016, 14:25 -
WMV files with errors: How to check + cut out bad frames, possible?
By DRP in forum Video ConversionReplies: 9Last Post: 11th May 2016, 21:33 -
Seeking utility to check for corrupt mpg or avi files
By jdlabelle in forum Newbie / General discussionsReplies: 11Last Post: 26th Aug 2015, 17:32
