Glad to see you're finally realizing the dangers of selling something you don't have clear rights to.
FYI, you may already be aware of this, but from the Netherlands Copyright law website:
"Copyright after death
If you die, copyright is automatically transferred to your heirs. Copyright ceases to apply 70 years after the death of the work’s creator."
And:
"Portrait right
If you film or photograph people, you will be the owner of the copyright but not the portrait right. The portrait right allows the portrayed person to prohibit the publication or copying of the photo or film. In many cases you must ask permission to publish a portrait. Portrait right falls under copyright laws."
https://business.gov.nl/regulation/copyright/
Results 31 to 34 of 34
Yes, I was aware. But I'll read through that link, something you can't do enough.
Copyright law is a bit different in every country. I'm not sure which one to use; where I live, where the company that is using the footage is, or where the footage was taken.
I do have several films from WWII, taken on 9,5mm. These films show nazi officers and soldiers.
Families of identified personnel can and have kept footage from being published/used. -
I am working on acquiring the latest 1080p scans of all the Apollo 16mm film as production-quality files. I will then be able to provide an even higher quality experience!
It will be expensive, but worth it. The quality boost from the 720p files I used previously is great. Takes a lot more time to render, but worth it.
Here is a video of the 1080p source found on archive.org.
NASA level video archival documents.
By digicube in forum RestorationReplies: 6Last Post: 7th Mar 2019, 05:53 -
Would you double the FPS for interlaced footage
By Sir_Loin in forum Video ConversionReplies: 4Last Post: 4th May 2018, 21:03 -
How to insert appropriate timecode in 120 or 300 fps footage?
By Heliooos in forum EditingReplies: 5Last Post: 14th May 2017, 09:48 -
Footage FPS is 29.95 and Client wants in 25 FPS
By maxfan in forum Newbie / General discussionsReplies: 5Last Post: 24th Apr 2016, 00:33 -
Help smoothing blocky edges
By Stevie Hyper in forum Newbie / General discussionsReplies: 10Last Post: 2nd May 2015, 21:42
