Hi, does anyone know a Region Code Hack for this GPX (Showview / LG) Player? Can't find anything in the list or the web.
Thanks!
if you search GPX - https://www.videohelp.com/dvdhacks?dvdplayer=GPX+&hits=50&Search=Search
you might try some of the codes listed, if none work then you may be out of luck. -
thanks for your reply!
yeah i tried all of those and also the LG, Silva Schneider and Zenith ones
Region code problems with dvd player RJ-700DVX
By jpwolfer in forum Newbie / General discussionsReplies: 3Last Post: 4th Nov 2019, 08:20 -
Region Code setting for a LG BP325 DVD player---can anyone help?
By BucketList in forum DVD & Blu-ray PlayersReplies: 0Last Post: 1st May 2016, 14:23 -
Apex AD-1500 region code hack
By Slickone in forum DVD & Blu-ray PlayersReplies: 3Last Post: 12th Feb 2016, 15:01 -
Blu-ray hack for region code
By SamsungBD in forum DVD & Blu-ray PlayersReplies: 1Last Post: 8th Feb 2016, 15:54 -
Will firmware update undo region code hack?
By keepingup6 in forum DVD & Blu-ray PlayersReplies: 9Last Post: 2nd Jun 2015, 04:39
