I am having difficulty getting this .avi file to play audio. I am utilizing the latest version of MPC+HC (ver. 1.7.13).
I am getting the following error code: MPC+HC could not render some of the pins in the graph, you may not have the needed codecs or filters installed on the system.
LAV Splitter Source:: Audio
LAV Splitter Source::Audio
Media Type 0:
Audio: 0x029a 8000Hz mono 32kbps
AM_MEDIA_TYPE:
majortype: MEDIATYPE_Audio {73647561-0000-0010-8000-00AA00389B71}
subtype: Unknown GUID Name {0000029A-0000-0010-8000-00AA00389B71}
formattype: FORMAT_WaveFormatEx {05589F81-C356-11CE-BF01-00AA0055595A}
bFixedSizeSamples: 1
bTemporalCompression: 0
lSampleSize: 256000
cbFormat: 20
WAVEFORMATEX:
wFormatTag: 0x029a
nChannels: 1
nSamplesPerSec: 8000
nAvgBytesPerSec: 4000
nBlockAlign: 4
wBitsPerSample: 4
cbSize: 2 (extra bytes)
pbFormat:
0000: 9a 02 01 00 40 1f 00 00 a0 0f 00 00 04 00 04 00 š...@...*.......
0010: 02 00|08 00 ....
Media Type 1:
Audio
AM_MEDIA_TYPE:
subtype: Unknown GUID Name {AFBC2343-3DCB-4047-9655-E1E62A61B1C5}
formattype: Unknown GUID Name {35189950-CAC9-4C8D-819D-B6FAEE15DD9D}
lSampleSize: 256000
cbFormat: 26
WAVEFORMATEXFFMPEG:
nCodecId: 0x0000
WAVEFORMATEX:
wFormatTag: 0x029a
nChannels: 1
nBlockAlign: 4
wBitsPerSample: 4
pbFormat:
0000: 00 00 00 00 9a 02 01 00 40 1f 00 00 a0 0f 00 00 ....š...@...*...
0010: 04 00 04 00 02 00 08 00|2e 00 ..........
My System Specs are as follows:
Windows 10 64 bit, AMD Ryzen 7, 1700x, 64 GB Ram, GeForce GTX 1080 Ti (Driver Vers. 445.97 latest)). My system has all the latest Windows & Drivers Updates.
I made a bug report, and this is the response I received: "Try opening the "video_ts.ifo" file with the player. You seem to be playing a .vob file now." I have no idea what this means, since there is only 1 .avi file I am trying to play.
The individual I received the file from claims he can hear audio, but he is using a much older version of MPC+HC, and I am not sure I believe he is hearing audio when playing this particular file.
I have tried other video players, including VLC. I tried downloading a K-Lite codec pack. I tried downloading LAV filters, as this was recommended from the MPC+HC site to troubleshoot problems playing .avi files. I have tried opening the file on another system. I am losing patience, and am likely to just go watch the file on his system.
In any event, please help. I have spent hours on this, and I do not want to encounter this problem in the future when trying to play files received from this individual.
Results 1 to 10 of 10
Not enough information. Would be helpful to post even a 5-10second clip.
Anyways, suggests it is using an old codec that used to be installed or available on older Windows OS like XP, such as Intel IMA audio codec, that isn't available or installed by default on newer windows.
In that situation, you'd have to look around for 3rd party codec packages to install and try to see if it enables such.
eg. http://www.cccp-project.net/
https://www.videoconverterfactory.com/tips/best-codec-pack.html
https://download.cnet.com/Windows-Media-Codec-Pack/3000-13632_4-75222206.html
For example, some older WMV files don't play correctly in modern Win10 without such. -
What does MediaInfo say about that pesky .AVI file?
If it contains an uncommon type of audio compression OR if the audio type was mislabelled by the .AVI muxig application
then the software player will not find a suitable decoder for the audio stream.
P.S.: assuming that the AVI file actually is an AVI and not a renamed VOB, for example."Programmers are human-shaped machines that transform alcohol into bugs." -
UPDATE:
Q: "Media Player Classic could not render some of the pins in the graph" errors
A:
This usually means that there is a filter missing that is needed to decode one of the streams in the file. The error message should show some information about the required format, but this information is very cryptic. Below you can find some of the values that the error might show you, together with the format that belongs to it.
subtype: Unknown GUID Name {726D6173-0000-0010-8000-00AA00389B71}
The format above is AMR audio. To play this you need to enable AMR in LAV Audio decoder or ffdshow audio decoder.
source: https://codecguide.com/faq_mpc.htm"Programmers are human-shaped machines that transform alcohol into bugs." -
I am unable to provide a sample. I'm sorry, but it is confidential.
This was the information that mediainfo provided:
General
Complete name : D:
Format : AVI
Format settings : rec
File size : 67.6 MiB
Duration : 28 min 41 s
Overall bit rate : 329 kb/s
IsTruncated : Yes
Video
Format : AVC
Format profile : High@L3
Format settings : CABAC / 2 Ref Frames
Format settings, CABAC : Yes
Format settings, Reference frames : 2 frames
Codec ID : H264
Bit rate : 274 kb/s
Width : 704 pixels
Height : 480 pixels
Display aspect ratio : 3:2
Frame rate : 30.000 FPS
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.027
Stream size : 56.3 MiB (83%)
Audio
Format : 29A
Codec ID : 29A
Duration : 28 min 40 s
Bit rate : 32.0 kb/s
Channel(s) : 1 channel
Sampling rate : 8 000 Hz
Bit depth : 4 bits
Stream size : 6.56 MiB (10%)
Interleave, duration : 33 ms (1.00 video frame) -
"The format above is AMR audio. To play this you need to enable AMR in LAV Audio decoder or ffdshow audio decoder."
I'm sorry, but please provide further details on how to do this exactly. TYI. This is in the MPC+HC options?
In the options setting of MPC+HC settings, I have selected LAV Splitter, LAV Splitter Source, and LAV Audio Decoder. When double-clicking the LAV Audio Decoder, in the formats section, AMR is selected. It is deselected in the Player--->Formats Section. Are these the proper options selections to make the AMR file play utilizing the LAV decoder?Last edited by twd42; 22nd Apr 2020 at 15:42.
Still have not gotten this to work. Any additional assistance please? I never received responses to my additional inquiries.
Thanks so much in advance. -
Install 32 bit ffdshow if your are using 32 bit mpchc, 64 bit ffdshow if you are using 6 bit mpchc:
https://www.videohelp.com/software/ffdshow
Enable ffdshow's AMR decoder if it's not already. Start -> All Programs -> ffdshow (x64) -> Audio Decoder Configuration (x64) -> AMR -> libavcodec
MPCHC should now be able to play the audio.
Question about AC3 Filter with MPC to increase sound when playing avi
By jimdagys in forum AudioReplies: 3Last Post: 13th Jan 2019, 16:50 -
Struggles when playing back certain 4K files in MPC-HC
By Greaseddog in forum Software PlayingReplies: 14Last Post: 28th Dec 2018, 07:44 -
AVI file not playing
By SupersonicJak in forum MacReplies: 10Last Post: 9th Oct 2016, 18:44 -
DVD only playing in MPC, not working in VLC or anything else
By twinaleblood in forum Video ConversionReplies: 1Last Post: 4th Jul 2016, 02:59 -
MPC-HC not playing subs with different name from video file...
By Balema in forum Software PlayingReplies: 19Last Post: 6th Apr 2016, 12:01
