Hi. is possible to make more faster converter video using gpu nvidia handbrake?
if i use leawo GPU very fast because it take 80-100% gpu usage. i don't know how to setting make for handbrake faster like leawo.
handbrake just take 20-23% GPU usage, that why take to long finish.
leawo 80-100% GPU usage
https://photos.app.goo.gl/KgW2AAWt6uMQCbrg9
handbrake 20-23% GPU usage
https://photos.app.goo.gl/u255tNoYknxqnXNS9
let me know if there is another way to make fast like leawo.
thank you.
try checking your graphics card and see if it has the latest driver update.
https://handbrake.fr/docs/en/latest/technical/performance.html
Simply adjusting Handbrake presets and settings affects encoding speed significantly.
Even sliding the encoder speed to FAST will make it go faster.
Test everything with NO AUDIO or AUDIO set to PASS-THROUGH.
If you enable audio re-encoding to AAC, for example, encoding speed will drop in Handbrake. Pass-Through is ideal.
If you let the encoder decide (variable bit rate), then it might go crazy and try to make a huge encode for no good reason in some rare cases. You'd have to set a fixed bitrate if the HB encodes are much bigger than the L encodes.
IS there any cropping or deinterlacing turn on/active?
This will slow things down.
Custom Crop - 0,0,0,0 top,bottom, left,right
DEINTERLACE detection and DEINTERLACE OFF
NVEncC by rigaya - NVIDIA GPU encoding
By Selur in forum Video ConversionReplies: 91Last Post: 5th Dec 2024, 12:55 -
Handbrake doesnt take my gpu
By BlurayHD in forum Newbie / General discussionsReplies: 4Last Post: 28th Mar 2020, 17:06 -
GPU Accelerated AV Converter multi-formats for nVidia CUDA Hardware.
By sev7en in forum Newbie / General discussionsReplies: 0Last Post: 21st Oct 2019, 02:29 -
There is too much about GPU vs CPU encoding, but how about GPU filters?
By Bernix in forum Newbie / General discussionsReplies: 24Last Post: 16th Feb 2018, 16:17 -
ffmpeg nvidia-gpu-accelerated encoding using NVENC - commandline settings
By hydra3333 in forum Video ConversionReplies: 3Last Post: 7th Sep 2016, 09:11
