I have downloaded nnedi3 plugin from the Avisynth wiki but what I want to know is how do I install the .dll file into Avisynth and Virtualdub? Can anyone here give me a step-by-step guide on how to install nnedi into those two programs?
	You can't install it for virtualdub - it's compiled as an avisynth plugin not a virtualdub plugin . You can use it indirectly in vdub / vdub2 through an avisynth script
 For avisynth, extract the appropriate version from the zip file in the folder depending on which cpu architecture , OS, and version of avisynth you are using, put the .dll in the avisynth plugins directory to autoload . The folders are labelled , choose the version that matches your setup
	Soyou just put the .dll file in Avisynth plugin folder? How do you make the script so Virtualdub can recognize it by proxy?
	You create a script that opens your media file and applies the nnedi3 filter.
 Save the script and open it with Virtualdub2
	Use a plain text editor like Notepad to create the script. Be sure to specify .AVS as the extension (not .TXT).
 AviSynth+ adds a context menu that lets you create a script by right clicking in an empty space in a folder (or Desktop) and selecting New -> AviSynth+ Script. That will create an empty script which you can edit with Notepad.
  Need help updating Color Mill plugin for VirtualDub2 to 64bitBy Bassquake in forum ProgrammingReplies: 9Last Post: 1st Oct 2024, 21:29
  Avisynth+ not refreshing in VirtualDub2By Chief Mouse in forum Video ConversionReplies: 2Last Post: 6th Sep 2019, 17:18
  Can't open an AviSynth script in VirtualDub2By Bruce Banner in forum EditingReplies: 4Last Post: 7th Jul 2019, 20:43
  Which Nnedi3.dll do I need for Avisynth?By VideoFanatic in forum Video ConversionReplies: 16Last Post: 17th Apr 2018, 15:55
  AVISynth+ and AssRender PluginBy smike in forum EditingReplies: 2Last Post: 1st Feb 2016, 20:55
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
