I want to compress a audio from bluray and i don't know the quality setting for 7.1 channels. what bitrate is the most used for this type of audio?
For AAC you can use variable bitrate encoding and select a quality instead, so it works much like selecting a CRF value for x264 rather than a bitrate. What's your desired output format, because obviously the type of encoder used will make a difference. Without knowing that it's a bit like asking what bitrate to use to compress video without knowing the encoder type.
If you are wanting AAC for the output, you might want to read this
https://forum.videohelp.com/threads/377639-7-1ch-AAC-encoding#post2438694
but the bottom line is for 7.1ch AAC encoding, you probably should use QAAC.Avisynth functions Resize8 Mod - Audio Speed/Meter/Wave - FixBlend.zip - Position.zip
Avisynth/VapourSynth functions CropResize - FrostyBorders - CPreview (Cropping Preview)
7.1ch encode
By davidcameron in forum AudioReplies: 0Last Post: 13th Apr 2020, 09:07 -
Need Help! LPCM, TrueHD & 7.1ch to AC3!!
By botdvd in forum Video ConversionReplies: 4Last Post: 28th May 2016, 22:21 -
7.1ch AAC encoding
By hello_hello in forum AudioReplies: 2Last Post: 27th Mar 2016, 01:33 -
AC3Filter Not Upmixing Properly From 5.1 to 7.1ch
By kairukun in forum AudioReplies: 9Last Post: 22nd Aug 2015, 09:37 -
DTS 7.1ch audio to 7.1 WAV conversion?
By kairukun in forum Blu-ray RippingReplies: 1Last Post: 5th May 2015, 02:42
