  1. I want to render some of my videos in 4K, but the software crashes when I try to process it. 2K is fine but I don't understand what's an issue with the higher resolution. Can anyone help?
    Mar 2008
    Are you using the 64 bit Virtualdub2 ?
  3. I used to but the same problem occurs
  4. Need more info on the input video, filters used if any, encoder and settings used
