Hi everyone,
I'm new here and I hope I arrived to the right place.
I'm trying to stream Interstellar.2014.2160p.UHD.BluRay.REMUX.HDR.HEVC. DTS-HD.MA.5.1-EPSiLON.mkv on my Chromecast Ultra.
Video wise, not an issue. However, I cannot hear the audio.
Seems that CCU doesn't support DTS.
I downloaded XMedia Recode to try and convert just the audio track to E-AC-3 on 5.1. Seems that this is supported by CCU. Got it from here.
When I played the converted video, all of a sudden the video file was not supported by CCU.
I chose the file format to be MKV, which is exactly like the original one.
So my problem is finding how to keep the original video (bit rate, resolution, quality) but only convert the audio track so I can stream it and play it on my CCU.
By the way, if I use VLC, the audio is playable but the video is choppy. Probably VLC is taking some part in processing the audio?
I use my Android phone to connect to my DLNA (router+HDD) and stream the file from the HDD to my CCU. I can play 4K movies with no issues, it's just this scenario that I'm having a problem with.
Appreciate any help on this matter.
Thanks!
Try StreamFab Downloader and download from Netflix, Amazon, Youtube! Or Try DVDFab and copy Blu-rays!
Results 1 to 1 of 1
convert an audio track from 24 to 23.97 fps with Audacity
By Alice in forum AudioReplies: 2Last Post: 6th Mar 2019, 09:51 -
Issues with Chromecast Ultra Setup
By Chopmeister in forum Media Center PC / MediaCentersReplies: 2Last Post: 27th Jun 2018, 14:48 -
convert an audio track from 23.97 to 29.97 fps with Audacity
By Alice in forum AudioReplies: 3Last Post: 6th Dec 2016, 20:01 -
advice - latest (best) audio codec to use in MP4 files for chromecast
By hydra3333 in forum Newbie / General discussionsReplies: 1Last Post: 17th Nov 2016, 19:22 -
Convert Videos for Playing on Chromecast - PowerShell script
By V1de0Luvr in forum Video ConversionReplies: 2Last Post: 30th Jun 2016, 09:37
