hi there
i have alot of vhs tapes a
that i would like to convert to usb.
also have video 8 tapes also would like to get to usb
what is an easy way to do this
There will be tons of threads, tons of opinions re: quality vs simplicity here.
Imo for simple:
https://hauppauge.com/pages/products/data_usblive2.html
https://www.elgato.com/en/video-capture
On the complex end with tons of equipment, software, post processing, search the other threads. -
Also "good" vs. "garbage". You must choose cards wisely.
Aside from the capture card, software is important (VirtualDub!) and codec (Huffyuv!)
Plus a quality VCR / TBC hardware to even allow a good capture experience.
It's not a simple binary choice. Reading/research required, adequate budget required for the task.Want my help? Ask here! (not via PM!)
Newbie help VHS tape conversion using dv camcorder or newer usb dongle ?
By Nickv48 in forum Capturing and VCRReplies: 2Last Post: 15th Feb 2020, 01:47 -
Converting old VHS to PC via USB converter - help please
By CptJack in forum Newbie / General discussionsReplies: 16Last Post: 2nd May 2018, 00:10 -
Device not detected on VHS to USB Capture-Converter
By hello0 in forum Capturing and VCRReplies: 10Last Post: 26th Jun 2017, 07:46 -
Free software to record from VHS via USB?
By kelemvor in forum Capturing and VCRReplies: 13Last Post: 6th Feb 2017, 08:42 -
Need a recommendation for a good USB recording card (dongle) for VHS record
By gil900 in forum Capturing and VCRReplies: 30Last Post: 25th Jan 2016, 18:11
