Hi there,
which quality video cams can you recommend for classical music videos? FullHD at 60 fps minimal, but 4K would be nicer. Need to keep them (at least 2 pcs) in sync with a Sound Devices MixPre 10 ii. Whole setup should be able to run on bats for 3 hours min. Small form factor would be a huge plus.
Best regards and many thanks in advance for your recommendations!
Hi Avstropiteks,
thanks for your reply. I would like to map the options and decide the budget then, so don't have any particular one in mind. -
Do you need true genlocked sync (using a separate generator to feed the mix pre as well as the cams) or were you expecting to do tc start jam + free run?
If this gets more involved, I could help w suggestions, but probably only in a month, as am at pre-semester crunch time ATM.
Scott -
Hi Scot,
I don't have a preferred way to implement the sync. Would be happy about anything practical.
Youtube Music Videos Sound Levels
By FAST-ED in forum Video ConversionReplies: 1Last Post: 21st Apr 2017, 14:34 -
Good website for thousands of hours of classical music stream or download
By jimdagys in forum AudioReplies: 0Last Post: 12th Apr 2017, 08:14 -
Sound Effects and Background (Non-copyrighted) Music
By harjo02 in forum AudioReplies: 8Last Post: 7th Feb 2016, 09:26 -
how to remove bgm music and only keep the sound effects
By quatro in forum AudioReplies: 7Last Post: 1st Nov 2015, 23:41 -
Capture 2 cams to pc and remote trigger
By Sebastien F in forum CapturingReplies: 4Last Post: 28th Apr 2015, 08:12
