I followed the directions from http://forum.doom9.org/showthread.php?t=172124 to install 32-bit AviSynth (because 32-bit is required for the watermark filter). The batch script says:
The machine is brand new. When I first ran the batch script, the first line also said:Code:Installed Avisynth version(s): 32 bit: 64 bit: Avisynth (x64) is not installedI test it with a simple AVS script,Code:Avisynth (x86) is not installedand the file fails to play in Windows Media Player and also in Media Player Classic.Code:Version()
How can I install 32-bit Avisynth?
Results 1 to 12 of 12
avisynth is NOT a playable file. Do some more reading of how it works.
Tip: a. Create avs script b: load script in a program that supports avisynth scripts such as virtual dub c: encode video d: then use your player to play the resultant file -
If Groucho's batch script didn't work for you, just try the old-fashioned
method:
https://www.videohelp.com/software/Avisynth"Programmers are human-shaped machines that transform alcohol into bugs." -
El Heggunte: thanks for the link. I forgot to mention that I want to work with AviSynth+ 3.4 to use FFMS2 (in order to deal with MTS and MP4 files). The homepage http://avisynth.nl/index.php/Main_Page suggests that AviSynth+ exists in 32-bit version. Yet the universal installer lists AviSynth and not AviSynth+, and your link suggests that the 32-bit version is for AviSynth up to version 2.6.
This thread: https://video.stackexchange.com/questions/29137/errors-in-ffmpegsource2-plugin-source-...r-for-avisynth mentions that AviSynth+ 3.4 has a 32-bit version. Last time I tried installing a 32-bit version on a 64-bit computer, I changed the registry keys, and got a blue screen of death. So I'd like to avoid that and be sure of how to install 32-bit AviSynth+.
Does AviSynth+ 3.4 32-bit not exist?
DB83: No, avisynth is not a playable file. I created a file `test.avs`
containing only `Version()` and this is the one that failed to play. -
I have both versions installed without any problem .. Universal Avisynth Installer
[Attachment 52825 - Click to enlarge]
[Attachment 52824 - Click to enlarge]Last edited by sekininsha; 22nd Apr 2020 at 07:29.
責任者-MDX -
^^ For the sake of clarity, do confirm that your file 'test1.avs' is actually a movie since MPC-HC, or atleast the version I use, can not render a plain text file. In fact no player can render a text file.
If it is a movie then by naming it '.avs' rather clouds the topic. -
In sekininsha's screenshots, those mpc screenshots indicate test1.avs is just a 1 line script, and technically a plain text file with a renamed extension from .txt to .avs
Code:version()
That is the script
It creates a "video" 10sec long 384x104, 24fps , RGB24 displaying that avisynth info. If it works, and you see it display like those screenshots, then avisynth is being initialized correctly through that application
It's just frameserving - when you open that .avs in mpc or vdub2 , it "looks" like a video file
The OP knows about this because he mentions version() in the 1st post. sekininsha is indicating there was no problems using the universal installer on his system -
Which watermark filter ? Maybe there is another version or workaround available ?
Why 3.4 ? Why not 3.5.x ? FFMS2 works in 3.5.x . And LSMASH is another source filter option
Both x86, x64 versions are in the latest official releases (and they work on multiple platforms now, even OSX, Linux (!) )
https://github.com/AviSynth/AviSynthPlus/releases
I Accidentally Installed AviSynth+
By koberulz in forum Newbie / General discussionsReplies: 2Last Post: 10th Feb 2019, 05:16 -
Avisynth 64 Bit + LSMASHVideo 64 Bit
By kalemvar1 in forum Video ConversionReplies: 4Last Post: 12th Dec 2018, 03:49 -
Avisynth - Anime Blu-ray with downscale fails
By Ninelpienel in forum EditingReplies: 15Last Post: 26th Aug 2015, 17:06 -
How to Convert 10-bit to 8-bit with AviSynth?
By MrBiggles in forum Video ConversionReplies: 4Last Post: 6th May 2015, 04:38 -
What 10-bit colorspace can I use with avisynth?
By -Habanero- in forum Newbie / General discussionsReplies: 20Last Post: 25th Apr 2015, 23:12
