Just took my reliable Sony HVR Z5 of of storage. Video is fine but mute. No audio input showing on monitor. Have tried switching external mics and using internal mics only but no result. Any suggestion? I'm not into silent movies....
is this during playback or recording ??
1st - try resetting the camera back to default settings.
2nd - remove all batteries (including any button cell batteries)
and let the camera set for a few minutes. try both of those
tips and then see if the audio now works. -
Thank you so much for your prompt response. That fix really worked. Removed battery for 5 minutes. Replaced, powered up, and audio works fine. So grateful to be back up and running. G.
Optional silent track?
By adrian44 in forum Newbie / General discussionsReplies: 0Last Post: 7th Nov 2019, 09:11 -
How to change fps for silent movies
By Enrik in forum Video ConversionReplies: 4Last Post: 15th Jul 2019, 05:11 -
Silent Film Style [Effect]?
By Round_Brix in forum EditingReplies: 2Last Post: 19th May 2017, 07:04 -
Adding a silent section
By efiste2 in forum AudioReplies: 1Last Post: 2nd May 2016, 16:58 -
VHS to DVD converting - silent sound
By Everything Audio in forum Capturing and VCRReplies: 0Last Post: 8th Nov 2015, 21:40
