I am interested in Epiphan AV.io HD. Be besides HDMI and VGA I want to capture composite from VHS, Betacam in HD via HDMI. Can someone help me compare:
GTV-COMPSVID-2-HDMIS https://www.gefen.com/product/composite-hdmi-scaler-GTV-COMPSVID-2-HDMIS
KanexPro CON-AV-HD4K https://www.kanexpro.com/item/?id=CON-AV-HD4K
I know the big difference is that the Gefen has the optical input for audio. Are there any other features or benefits in picture quality to be gained with the Gefen over the KanexPro? Does the Gefen have useful adjustments that can be made where the KanexPro does not?
thanks.
Upscaling VHS to HD? This probably won't end well.
Why?
What is the reasoning?
Picture quality is often harmed, there are almost always zero (negative!) benefits.Want my help? Ask here! (not via PM!)
VHS best captured from S-Video using a S-VHS machine, Betacam best transferred from SDI after being internally captured inside a Betacam SDI equipped player and streamed in 1:1 via a SDI to USB adapter. If you are doing this for a client they expect you to know better.
up-scale, a new small and simple Upscaler
By ProWo in forum Video ConversionReplies: 14Last Post: 30th Nov 2021, 12:12 -
Video upscaler help please
By hdfills in forum Capturing and VCRReplies: 1Last Post: 27th May 2017, 20:46 -
Composite Capture from VHS -- lose signal
By poncho524 in forum Capturing and VCRReplies: 3Last Post: 20th Sep 2016, 08:30 -
Looking for talented upscaler for commision work!
By focus187 in forum Video ConversionReplies: 4Last Post: 30th May 2016, 19:20 -
real-time, on-the-fly, web upscaler to 1440p?
By savvyguy in forum Newbie / General discussionsReplies: 8Last Post: 7th Jul 2015, 10:11
