Hi, I've ripped a DVD9 with DVD Decrypter, I've a list of .VOB files. Every file doesn't contain a full episode, I don't know how to discover in a precise way where an episode finishes. I'm on linux and I'd like to encode them (in order to generate .mkv files) using linux tools, if it's possible I'd like to avoid to use windows. This is the first time I perform a similar operation but I know some theory.
[Attachment 52755 - Click to enlarge]
Every file has 3 subtitles and 3 audios, .rar files contains extras that I don't want to encode for the moment.
Could you provide me some guide/documentation and suggest me some tool? I suppose I can use FFmpeg. If you have a lot of material to recommend, it is not a problem, I'm ready to learn. I'd like to use h264 codec with ac3 audio or aac.
MakeMKV - https://www.videohelp.com/software/MakeMKV
runs on LINUX
Splitting or trimming raw VOB or MPG files without re-encoding?
By DF001 in forum Capturing and VCRReplies: 3Last Post: 14th Mar 2020, 22:53 -
Linux based tools that have MPEG1 CBR with the CBR flag ?
By werdmai in forum Video ConversionReplies: 7Last Post: 28th May 2019, 17:55 -
Best tools to extract files from DVD
By kodec in forum Authoring (DVD)Replies: 2Last Post: 12th Jan 2018, 16:30 -
Looking for free tools to cut part of mp4 without re encoding it ?
By method in forum EditingReplies: 5Last Post: 9th May 2016, 13:11 -
Merging AVI Files With Avidemux In Linux
By rstuff in forum Video ConversionReplies: 3Last Post: 4th May 2016, 23:14
