Results 1 to 17 of 17
  1. Can anyone tell me how to download this show:
    https://www.tg4.ie/en/player/categories/drama-tv-shows/play/?pid=5726487603001&title=R...a&pcode=047990
    The m3u8 is
    http://manifest.prod.boltdns.net/manifest/v1/hls/v5/fairplay/1555966122001/49c6121c-5b...IyZDBlNw%3D%3D
    I've been after it for ages and it's just been put back on the site after two years,
    so any help would be greatly appreciated.
    Jul 2017
    North Pole
    The m3u8 is
    question arises how did you get the master m3u8 file for a protected stream..
    i guess this is something which won't be discussed on this forum..
    (widevine protection)
    HTML Code:
    [hls,applehttp @ 0453ade0] SAMPLE-AES encryption is not supported yet
  3. question arises how did you get the master m3u8 file for a protected stream..
    Fiddler lists all the m3u8 and mpd manifests in JSON.
    Key request URLs, licences etc are also listed.
    https://manifest.prod.boltdns.net/license/v1/fairplay/1555966122001/49c6121c-5b52-4741...M3YjNjYg%3D%3D
    I gather the m3u8 is needed together with the key.
  4. bro Use youtube-dl
    use this command
    this will list all the formats and you are good to go!
  5. and you are good to go!
    Question: Why say that if you haven't actually downloaded it?
    [hls @ 05033980] Failed to open segment 141 of playlist 0
    [hls @ 05033980] SAMPLE-AES encryption is not supported yet
    [hls @ 05033980] Failed to open segment 142 of playlist 0
    [hls @ 05033980] Failed to open segment 143 of playlist 0
    [hls @ 05033980] Failed to open segment 144 of playlist 0
    [hls @ 05033980] Failed to open segment 145 of playlist 0
    [hls @ 05033980] Failed to open segment 146 of playlist 0
    [hls @ 05033980] Failed to open segment 147 of playlist 0
    [hls @ 05033980] Failed to open segment 148 of playlist 0
    [hls @ 05033980] Error when loading first segment 'http://tg4bcbolt-a.akamaihd.n
    et/media/v1/hls/v5/fairplay/1555966122001/49c6121c-5b52-4741-b2c4-4b97c225c56a/4
    a77ef80-5c33-4345-ba0a-b11f140cb3db/2a6e82be-3a26-4027-b1a0-b147050066c0/5x/segm
    ent0.ts'
    21c-5b52-4741-b2c4-4b97c225c56a/4a77ef80-5c33-4345-ba0a-b11f140cb3db/10s/renditi
    on.m3u8?fastly_token=NWViZTdmOTNfNTAxOTNkYWZiZjdmY 2NhZThjNDgyNTAxZjMzNDYwYjJlNWR
    jMjA2ZGQ1YzljNjljMWRhZTg0NjI0MTdlMzQ2Mg%3D%3D: Invalid data found when processin
    g input
  6. confirmed: yt-dl "manifest" does not work... bad post dipenmakdani.... try before posting.
    Jul 2017
    North Pole
    he didn't try, and if he did.. he realized the stream is DRM protected after seeing all the messed up pixels on his screen...
    ,and youtube-dl does not support such. ;-P
  8. ok. and so nothing works?
  9. I have several movies that I would like to download but I don't know why I can do it, I would also like them to come with a language in Spanish or in that case subtitled. la película es esta: cinecalidad movie
  10. Minds suspishos's Avatar
    Jul 2021
    southern hemisphere
    Dont Get this throw it away and get EaseUS RecExperts.
    Glad i found this i have the same trouble and i figured if you havnt solved it to download then its Record the Screen with Cam Studio or somethin.
  11. Minds suspishos's Avatar
    Jul 2021
    southern hemisphere
    EaseUS RecExperts Get It.
  12. Originally Posted by Kamala View Post
    I see it is mpd url, but red: https://manifest.prod.boltdns.net/manifest/v1/dash/live-baseurl/bccenc/1555966122001/4...BiZGVhMA%3D%3D
  13. Minds suspishos's Avatar
    Jul 2021
    southern hemisphere
    Yes its the .MPD Link Not the .M3U8, the MPD is directly under the M3U8 and this is how you get it, right click the video click INSPECT or hit F12, the Elements window will open STAY ON ELEMENTS, above Elements and LEFT, TOP LEFT CORNER is 2 symbols click the top LEFT one then scroll over Video it will HIGHLIGHT The Video,click the Video then THE CODE WILL BE HIGHLIGHTED next to it, RIGHT CLICK THE CODE and select EDIIT AS HTML then You WILL SEE THE M3U8 and MPD, COPY MPD from SRC=" ? " everything Between the Apostrphes then then Download VLC Video Player open and then OPEN NETWORK STREAM, PASTE LINK IN THE URL BOX DONT CLICK PLAY CLICK CONVERT instead click browse to SAVE FILE to Desktop and then Click SAVE then CLICK START and let the BLUE LINE GO ALL THE WAY TO END UNTILL IT IS FINISHED and DONT USE MACHINE while it is Doing It unless You have a FAST MODERN ONE. Thats the only way I Know otherwise Record it with EASEUS RECEXPERTS.
  14. Minds suspishos's Avatar
    Jul 2021
    southern hemisphere
    how to use the .m3u8 the link has a TOKEN behind it you need to copy the entire Link with the TOKEN behind the .m3u8 like this
    https://?????????.m3u8?fastly_token=????????????????
    Then use VLC to downlod it intructions are on the VLC webS.
