Hello!
I have over 100 subtitles and on every one of them I want to add a text at the beggning "SAMPLE TEXT". ( a new line).
How can I do that and in what program ?
I think that with subtitleedit you can't ... if not someone correct me.
You can create a subtitle of intro (eg. 0~2 sec) with the line you want:
1
00:00:00,005 --> 00:00:02,000
"SAMPLE TEXT"
and join them with ffmpeg in a batch file... we make a text file: my_list.txt
file 'intro.srt'
file '%%a'
I have tried it and it works, I suppose that some expert can correct something .. I don't know ...Code:@echo set "ConcatScript=my_list.txt" for %%a in (*.srt) do ( (echo file 'intro.srt' echo file '%%~a' )>"%ConcatScript%" C:\ffmpeg\ffmpeg -f concat -i "%ConcatScript%" "%%~a.new.srt" ) pause
But it is a way out of your problem..責任者-MDX -
You think can do that with subtitle edit but you have to go in the settings and find the options.
Edit: Ah, sorry - misunderstood... don't think SE can do this.
You can use batch convert with offset time codes for all the affected srt with subtitle edit.
If I set for all subtitles to show 2 seconds ealier to get them in sync , the intro it's removed .
Sorry .. I had not seen this situation.It's working , but the problem is that is changing the timings and then the subtitle will be in out of sync.
Try ..
Start by applying the 'Offset time codes' (2,000/ Show earlier) in SE .. and then apply the batch adding the intro .責任者-MDX
How to add moving line in video?
By SinghLive in forum EditingReplies: 4Last Post: 6th Dec 2019, 16:10 -
OBS Add On That Encodes Text as Barcode?
By pone44 in forum Newbie / General discussionsReplies: 0Last Post: 7th Jul 2018, 02:37 -
One line of text in Aegisub
By Fragha in forum SubtitleReplies: 2Last Post: 25th Mar 2018, 18:03 -
Add dash to a continuing subtitle line?
By Rob- in forum SubtitleReplies: 5Last Post: 23rd Sep 2016, 10:31 -
certain subtitle lines showing as black text in multiple video players
By dstarfire in forum SubtitleReplies: 1Last Post: 22nd Feb 2016, 14:53
