long ago i hard encoded subtitles to a movie but i did the encoding in a bad way and the movie is pixelated and there are some scenes in which there are pixels in the whole screen
is it possible to fix this file and remove the pixels without having to reencode the movie? i have moviavi video converter 20 premium. can i use it to fix the video or i need to use another software?
You will have to re-encode the original movie with a decent bitrate.
How to fix video with low bitrate
By Wobulali in forum Newbie / General discussionsReplies: 1Last Post: 15th Dec 2019, 05:59 -
How do I fix audio drift in video?
By Cmclernon in forum AudioReplies: 9Last Post: 31st May 2019, 11:33 -
Improve blurry low quality video into clear high quality video.
By Osram123 in forum Video ConversionReplies: 2Last Post: 4th Apr 2016, 01:48 -
can i fix this video ?
By abdorefky in forum EditingReplies: 6Last Post: 1st Jan 2016, 00:24 -
x264vfw encoding first frames really low quality, how to fix that?
By Srivas in forum Video ConversionReplies: 3Last Post: 13th Nov 2015, 01:03
