  1. I have looked at various forums and the solutions mentioned in them haven't worked for me. I am playing back NTSC tapes which are in excellent condition on a Sony camcorder w/ TBC and DNR on. The camcorder is connected to a Tevion USB capture device. I am using Virtualdub. I have selected the following under Capture>Timing:
    • Drop and insert null frames both checked
    • Resync mode: do not resync
    • Correct video timing checked
    • Automatically disable resync checked
    • Audio latency determination: Automatic w/ value 30
    • DirectShow options: None checked
    With resync mode set to Do not resync, I get a huge progressive delay of about 2 minutes between video and audio. If sync audio to video is checked, the audio and video are more or less in sync; however, some parts of the audio have pitch issues which is expected as explained in Virtualdub's manual.
    It's worth noting that I have also tried AmaRecTV, but that program results in many scenes that have sped up video, so it's not really an option here.
    I have also tried the following solution offered by another user. The delay gets much lower (~4 seconds), but video and audio are still out of sync.
    Originally Posted by Abas-Avara View Post
    This is what I use for DV captures
    Method 1 (after DV AVI capture)
    - Open AVI in VirtualDUB
    - Go to video - Framerate and then select adjust audio/video to framerate
    - Save AVI (video: direct stream copy and audio: direct stream copy)
    I was wondering if there's a way to fix the delay issue without having to purchase a professional VCR.
    Mar 2008
    Don't use Vdub, try Amarectv or iuvcr
  3. Originally Posted by davexnet View Post
    I've already stated the problem with Amarectv. iuvcr is also known to have audio video sync issues.
    Why?
    VirtualDub works 99% of the time.
    Amarec is messy, not user friendly.
    icVCR is just downright obsolete, and works almost never.
    Mar 2008
    Originally Posted by retractOffer View Post
    Bump
    The forum is full of past threads with people trying to do the same as you are.
    See if there is anything useful here:
    https://forum.videohelp.com/threads/388626-Best-software-for-capturing
  6. Originally Posted by davexnet View Post
    Bump
    You obviously didn't bother reading my post. Twice.
    Mar 2008
    You're wrong, I'm just reading between the lines ...
