Hi,
So I've ripped a bunch of episodes from my dvds of a tv show, because I'd like to replace the audio tracks. The dvds are missing a lot of the music present in the tv broadcast.
I have all of the original tv version audio tracks, and I'd like to know if there is a software that could automatically synchronize those tracks with the dvd tracks (they contain the same dialogue, but a few black screens for commercials breaks would create delays).
I often use Subtitle Speech Synchronizer , it syncs the subtitles to the audio tracks I use as reference, and it works very well. So is there a speech synchronizer that would do the same but with two audio files?
Thank you.
Nothing fully automatic, but PluralEyes, and Premiere's Merge along w Synchronize, can take much of the manual work out of it. Those are mainly geared toward syncing clips in a multicamera recording & editing setup.
Scott -
I've just installed the shareware version of PluralEyes, it's compatible with Vegas Pro. And it seems to work, it says "clips synchronized", it adjusts them slightly but they're not synchronized, they're still very out of sync. I'm surprised, I read a lot of positive reviews about this software. But maybe it's not made for that kind of audio?
Split the tracks up into separate clips where the breaks occur, output them as individual wavs, then load those into PluralEyes.
That said, given that TV shows exist fairly large chunks, you should be able to manually sync it up in Vegas using the waveforms as a guide fairly easily.
Best text-to-speech voice?
By Aludin in forum AudioReplies: 13Last Post: 31st Jul 2019, 09:20 -
Loss of audio tracks
By dostrander in forum Newbie / General discussionsReplies: 2Last Post: 16th Mar 2017, 15:52 -
Sony DV Audio Tracks
By techtron79 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 8Last Post: 4th Feb 2017, 07:40 -
BDtoAVCHD 2.5.6 All Audio Tracks
By Toby2k in forum Blu-ray RippingReplies: 1Last Post: 2nd Jun 2016, 03:30 -
Add audio track to M4V that already has a variable number of audio tracks
By ppomes in forum LinuxReplies: 5Last Post: 5th May 2015, 20:21
