Hi all,
I know this is probably a simple question, and one that's been asked a million times... but I cannot figure it out and have spent many hours with a trial and error approach and I cannot get it to work!
I have a folder full of HEVC .mp4 video files each with a single audio streams each and upto 2 subtitles streams. My issue is they are tagged as HEV1 and I need them to be HVC1 to enable them to play nicely with quicktime. I can convert single files with the following (though do not think both subtitle streams work)
ffmpeg -i X.mp4 -c:v copy -tag:v hvc1 -c:a copy -ccopy C:\converted\X.mp4.
What I want is for ffmpeg to simply remux all the mp4 files in the directory, keeping the subtitles and audio and tagging it with HVC1.
Is that doable? Any advice will be gratefully received![]()
try ..
Code:for %%a in ("*.mp4") do ffmpeg -i %%a -tag:v hvc1 -c:v copy -c:a copy -c:s copy "%%~na.hvc1.mp4" pause責任者-MDX -
Also add -map 0 to map all tracks so that a 2nd subtitle track would not get lost (by default ffmpeg only maps 1 video, 1 audio and 1 subtitle).
https://trac.ffmpeg.org/wiki/Map -
Thanks for the help... though I have an issue still. I'm guessing its because the filenames have spaces? Though they are in " " so not sure what the problem is. I have hundreds I need to convert so i don't want to rename them all if I can help it!
Appreciate all the advice
[Attachment 52748 - Click to enlarge] -
I copied the following (as per sekininsha's message) into a batch file and ran it in the same directory as the files...
copy -map 0 "%%~na.hvc1.mp4"
pause
Is there something I'm missing here?
[Attachment 52749 - Click to enlarge]
How Find PBS MP4s?
By KermitJ in forum Video Streaming DownloadingReplies: 10Last Post: 23rd Aug 2019, 11:52 -
Problem converting MKVs to MP4s
By phkc070408 in forum MacReplies: 4Last Post: 26th Jun 2016, 03:59 -
Combining mp4s for iTunes apple tv 4
By Chris Newbold in forum Video ConversionReplies: 1Last Post: 23rd Apr 2016, 13:07 -
What do you convert your MP4s to before editing?
By brokenrobot in forum Video ConversionReplies: 5Last Post: 16th Feb 2016, 01:52 -
[Help] Remux Multiple MKVs into MP4s? (Windows 8.1)
By Kid Boruto in forum Video ConversionReplies: 5Last Post: 1st Aug 2015, 21:15
