Hi guys
I've been using VSDC Video Editor and when working with text objects this zoom effect is just not going smooth. Instead it starts shaking in the middle of the zoom, and I am talking about the final result, after exportation is finished, doesn't matter the video format, or FPS rate, or bit rate, the goddam shaking is always there.
Any ideas on how to fix it? Uploaded a sample here.
Try StreamFab Downloader and download from Netflix, Amazon, Youtube! Or Try DVDFab and copy Blu-rays!
Do you have some other effects or keyframes ? Maybe interpolation is not set to linear ?
Did you have a look at some video tutorials ? Maybe you're doing something differently ?
https://www.youtube.com/watch?v=WRP5dXd6OdQ
https://www.youtube.com/watch?v=USNR5ckU9Es -
I suspect what's happening is the videos are YV12 and the scaling, zooming, and overlay are done mod 2. Possible fixes: work in YV24 or RGB. Or upscale (4x?), overlay, downscale back to the original size.
Here's an example. On the top the zoom is with single pixel accuracy, fairly smooth. On the bottom everything is mod 2, shakiness similar to the OP's.
Panasonic AG4700/HS1000 noisy picture, jitter / shaky image, weird audio
By ofesad in forum RestorationReplies: 4Last Post: 15th Aug 2019, 17:13 -
shaky/blurry GOPRO Hero 7 video - how to improve quality?
By GR365K1 in forum Newbie / General discussionsReplies: 2Last Post: 15th Feb 2019, 09:33 -
Shaky video and distortion line on bottom on DVD
By litlin in forum Newbie / General discussionsReplies: 11Last Post: 13th May 2018, 08:23 -
picture is shaky/jitter please help
By kt2016 in forum RestorationReplies: 18Last Post: 14th May 2016, 00:04 -
Fixing a Shaky Focus and Color Grading with Vegas 13.0
By allez in forum EditingReplies: 2Last Post: 21st Aug 2015, 09:10
