Hey all. I recently lost my entire kodi media library of a few hundred films and tv shows to a spectacular hard drive malfunction (it blew up... don't ask) so I got myself a new drive and I'm back to redoing the entire library again from scratch. Most of my content is 1080p so nothing difficult about that, but I have a handful of dvd's (both pal and ntsc), mainly tv shows that have the tell tale interlacing lines. I put most of them through handbrake using deinterlace set to decomb with default preset and default detection and using same as source frame rate. For all but one tv show this works fine, the resulting videos I got were all deinterlaced to a nice dgeree and ran relatively smooth. I know from looking through this forum a lot of you pros seem to consider handbrake to be a pile of wank when it comes to deinterlacing videos, and I do have avisynth with a load of plugins instealled if needs must.
The one PAL dvd I was never happy with I put thru handbrake in the same way as the others (same as source frame rate, decomb on default preset and default interlace detection), but the result is the video is slightly jerky in motion in some areas (barely noticeable admittedly but it is there).
Video
ID in the original source medium : 224 (0xE0)
Format : MPEG Video
Format version : Version 2
Format profile : Main@Main
Format settings, BVOP : Yes
Format settings, Matrix : Default
Format settings, GOP : M=3, N=10
Format settings, picture structure : Frame
Codec ID : V_MPEG2
Codec ID/Info : MPEG 1 or 2 Video
Duration : 1 h 41 min
Bit rate mode : Variable
Bit rate : 4 946 kb/s
Maximum bit rate : 9 000 kb/s
Width : 720 pixels
Height : 576 pixels
Display aspect ratio : 4:3
Frame rate mode : Constant
Frame rate : 25.000 FPS
Standard : PAL
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Interlaced
Scan order : Top Field First
Compression mode : Lossy
Bits/(Pixel*Frame) : 0.477
Time code of first frame : 09:59:30:00
Time code source : Group of pictures header
GOP, Open/Closed : Open
Stream size : 3.51 GiB (96%)
Language : English
Default : No
Forced : No
Color primaries : BT.601 PAL
Transfer characteristics : BT.470 System B, BT.470 System G
Matrix coefficients : BT.601
selur's Hybrid is far better for this task.
It uses Vapoursynth or Avisynth and QTGMC, all options available.Want my help? Ask here! (not via PM!)
Resizing after deinterlace PAL DVD w/ QTGMC
By rilopes64 in forum DVD RippingReplies: 11Last Post: 3rd Dec 2019, 11:01 -
Cannot deinterlace certain videos with mpc-be + madvr + LAV filters.
By streetsofrage47 in forum Software PlayingReplies: 0Last Post: 4th Aug 2019, 17:45 -
Which DVD to use? PAL or NTSC, and which Deinterlace/Detelecine options?
By U2Joshua in forum Video ConversionReplies: 17Last Post: 16th Jan 2017, 20:59 -
[avisynth] what is the deinterlace method that use less CPU?
By marcorocchini in forum Newbie / General discussionsReplies: 5Last Post: 9th Nov 2015, 19:55 -
Best method to capture Hi8 home videos?
By Optical in forum Capturing and VCRReplies: 5Last Post: 29th May 2015, 17:02
