Hello,
So I've converted a bunch of mkv files from 25 fps to 23.976 fps, setting them at 24000/1001p with MKVToolNix. They play fine on my computer but the playback is very jumpy on my Sony blu-ray player. What I don't get is that I have some old mkv files that were also slowed down to 23.976 and those play fine on the same player.
The only difference I notice is that jumpy mkv files indicate 25.000 fps as the Original frame rate, while the ones that play fine only indicate the new Frame rate.
Is there a way to remove the Original frame rate flag? I'm thinking that would fix the issue. I've tried with JMkvpropeedit but I couldn't do it.
Than you.
	Try ticking "Fix bitstream timing info" when remuxing in MKVToolNix GUI. (It's slightly below where you set the fps.)
 How are you handling the audio?
	That did the trick, thank you!
 I ended up finding this command line for the audio, and it worked great:
 for %%a in (*.ac3) do ffmpeg -y -i "%%a" -map 0:0 -af asetpts='25025/24000*(PTS-STARTPTS)',aresample=48000:async=1:min_comp=0.01:c omp_duration=1:max_soft_comp=100000000:min_hard_co mp=0.3 -vn -c:a ac3 -b:a 640k -ar 48000 "%%~na.new.ac3"
	A couple of those mkv files were incorrectly ripped at 23.976 fps instead of 25 though, which results in a jerky playback, but I'm also unable to slow them down to the correct speed with MKVToloNix since 24000/1001p won't change the frame rate. Is there a way to fix those files by any chance?
  can't figure out original frame rate from NTSC laserdisc captureBy clashradio in forum Capturing and VCRReplies: 12Last Post: 6th Dec 2018, 17:55
  Understanding original frame rate & type for this clipBy Imy in forum Video ConversionReplies: 4Last Post: 16th Apr 2018, 15:26
  transcode Variable Frame Rate (VFR) AVC video to Constant Frame rate (CFR)By hydra3333 in forum Video ConversionReplies: 2Last Post: 4th Mar 2018, 06:01
  Variable frame rate into constant frame rate without re-encodingBy DunnoNo in forum Newbie / General discussionsReplies: 8Last Post: 21st Dec 2017, 12:05
  How to Determine Original DVD Frame Rate & Frame TypeBy lomaidala in forum Video ConversionReplies: 30Last Post: 3rd Jul 2017, 08:42
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
