I have a sony dv camcorder and am accumulating full dv quality video (AVI) to make a dvd movie with the edited sequences. I am using pinnacle 7 for this. with all the specs:
720 x 480
1536 kbps
29 frames / sec
audio is PCM
Problem. I am running out of hardrive space (120 GB). I would like to convert all the video to dvd compatibilty with the highest quality. I have TMPenc.
Question:
what is the highest of parameters that the dvd will allow to ensure I have a quality dvd. Is variable or constant bitrate better? If variable, what upper, average, and lower margins ---if constant, what is the highest that will still allow me to play in my component dvd (which is fairly new).
This is a one shot deal because I do not want to loose the original's quality once I convert to MPEG2 and delete the files. Are there any people out there that convert their digital video movies to dvd and have been successful?
Thanks in advance.
Matt
I have used TmpGenc to convert DV to DVD spec. I use 2pass VBR, average bitrate 6000, max 8000, High quality and it all looks pretty good. Make sure your audio is at 48khz sample rate or convert the audio with a different tool as TmpGenc is not very good at this. I can get about 90 mins of video onto one DVD-r with this method. Hope that helps.
Matt, would you please post your successes or failures of achieving the results you are after. I have started the same project and have not been satisfied with my results. It sounds like we are using the same software/hardware. Eric
Here's some info I found online:
If I'm encoding with VBR, what is a reasonable minimum and maximum for DVD-R?
Posted: Apr 23 07:30
i use 3000 and 8500 and am usually very satisfied with the results...
uteotw
Member
Posted: Apr 23 08:38
Max DVD bitrate is 9800 , so I substract the audio bitrate to find out the max video bitrate.
If I do TV captures I'll encode the audio at 224 , so max video = 9576
If I audio is 448 ac3 then the max video = 9352
When I analyze the encoded video with BitrateViewer I never saw a peak at my maximum bitrate. I think the highest I've ever seen is around 7000.
This works for me with A03 burner and 1.49£ DVD-R.
uteotw
shardison
Member
Posted: Apr 23 13:42
Try TMPGEnc's CQ mode instead of 2 pass VBR. I use 2000/6000 and the average comes in at about 3500kbs and no artifacts. (Old)2-pass has freaked out my DVD player for some reason. You can fit a lot of nice video on a DVD at 3500kbs.
SLK001
Member
Posted: Apr 25 06:55
The DVD standards are as follows:
MAX VIDEO BR = 9.8Mbps
MAX AUDIO BR = 912kbps
MAX STREAM BR = 10.08Mbps
I believe that the minimum video BR is 500kbps.
So, as a practical matter, using 384kbps audio, I set my MAX VIDEO BR to 9.5Mbps and my minimum to 1Mbps. Depending how much data I have, I set my average BR from 3.5Mbps to 5.5Mbps (usually 4.5Mbps).
But, as usual, your mileage may vary.
__________________________________________________ ________
Here is what I have found.
I took my DV original files captures with pinnacle 7 and I exported to MPEG2 using a custom set of settings. I used 9mb bitrate and the highest setting for the audio 384. The input file (AVI) was appox 3.79 gb and the output file was 327 mb in mpeg2 format. I used ULEAD dvd workshop to make my vob files and I tested the results with POWERDVD.
The clarity was as good as the original aVI even at full screen viewing. I don't currently have a dvd-r but will soon get one. THe only thing I found was that windows media player had problems with lags playing the mpeg2 file. After it was converted to VOB, power DVD was flawless.
Keep the replies coming
compatible video dvd specs for ps3 and xbox
By mrpersad in forum Media Center PC / MediaCentersReplies: 0Last Post: 9th Oct 2011, 01:34 -
How are these specs for video editing?
By vid83 in forum ComputerReplies: 16Last Post: 8th Feb 2009, 02:54 -
PC specs for video editing
By dainova in forum EditingReplies: 16Last Post: 5th Dec 2008, 11:30 -
How to find the exact parameters used to encode a video
By SoupNazi83 in forum Video ConversionReplies: 4Last Post: 18th Jul 2008, 19:10 -
Digital Betacam Models and Specs
By seb.tatut in forum Newbie / General discussionsReplies: 8Last Post: 7th May 2008, 14:24
