Greetings,
I've been encoding my videos using CRF 23 which is about 1500/3500 kb/s depending on the video, is that considered low bitrate for 1080p?. I'm asking because I've been using SAO filter since I read that it helps with ringing artifacts on low bitrate but after some comparisons, I noticed that disabling it results in preserving more details... so if my bitrate is high enough I'd rather disable it.
Thanks.
What bitrate differences do you get with --sao or --no-sao? That should not be much at all. Not sure how relevant it is to save bitrate or not.
For example a subtle denoise can save you 1/6, 1/7th of bitrate for regular camcorder video on the other hand. Or are you working with cartoons and --sao or --no-sao gives a bigger difference for bitrate while using CRF? -
The bitrate difference between --no-sao and sao is minimal. For example, the last video I compared is 2 745 kb/s (sao) and 2 726 kb/s (--no-sao) but with no-sao you keep more details... hair and moles aren't blurred for example, though I have to say I haven't compared ringing artifacts which sao is said to help with.
At first, I didn't notice any loss of details with sao vs no-sao but after doing more comparisons I started to notice...Last edited by Felow; 12th Apr 2020 at 07:12.
How to fix video with low bitrate
By Wobulali in forum Newbie / General discussionsReplies: 1Last Post: 15th Dec 2019, 05:59 -
VOB Files Decoding Very Low Bitrate
By Violator in forum Newbie / General discussionsReplies: 1Last Post: 20th Jan 2018, 07:46 -
Low video bitrate issue
By Paul M in forum EditingReplies: 15Last Post: 20th Aug 2016, 06:52 -
Bitrate for low motion
By Tafflad in forum Authoring (Blu-ray)Replies: 53Last Post: 8th Nov 2015, 15:01 -
Best encoder for MPEG-2 with low bitrate?
By Observer in forum Video ConversionReplies: 11Last Post: 25th May 2015, 17:36
