    Oct 2008
    Chile
    Hi, I have a lot of .ts video files with their respective .aac audio files, I joined one with avidemux but since they are many, I wanted to know if there's a tool to automate in batchs
  2. Try ..
    for %%a in ("*.ts") do ffmpeg -i "%%~na.aac" -i "%%~na.ts" -acodec copy -vcodec copy "%%~na.muxer.ts"
    pause
    output: ts or mp4 or mkv ..
    責任者-MDX
    Oct 2008
    Chile
    Originally Posted by sekininsha View Post
    Try ..
    pause
    I'm not very skilled on the command line, but I made sure I had ffmpeg in the window's 10 enviroment path, I tested it running ffmpeg command, it works fine, when I run your command on the folder where I have the .ts and .aac files it gave me this back
    %%a was unexpected at this time.
  4. are you executing this directly in the command prompt or it's in a batch file?.. you have to create a batch file (eg. remux.bat)
    or
    if you run your code in command prompt you should use only one: % .. in all the names.
    責任者-MDX
    Oct 2008
    Chile
    or
    Yes!! creating the batch file made it worked, you are awesome, just what I needed thank you
