Results 1 to 11 of 11
  1. I have tried everything short of throwing the kitchen sink at this - plays fine (via vpn set to USA) however unable to save the stream - any pointers? new anti download protection?
    https://www.oxygen.com/kim-kardashian-west-the-justice-project/season-1/special-episod...st-the-justice
  2. IDM or Youtube-dl ( use master.m3u8 URL).
  3. Originally Posted by LZAA View Post
    Thanks for you reply - the above didn't work for me as I had tried using them before posting my question however I have since discovered that the Chrome Add-on 'Video DownloadHelper' worked where all the rest failed.
    Jul 2017
    North Pole
    neither working, you probably didnt even try.
    Jul 2001
    Brazil
    try use tool link removed
  6. Originally Posted by lafamar View Post
    what is that?? link to developper?? you post this software everywhere but you do not provide explanations of what it is or even who developed it...
    MY ADVICE: DO NOT TRUST THIS PROGRAM
    the user does not provide explanations, repeatedly requested in other different posts.
    Jul 2017
    North Pole
    exactly.
    the exe file has information edited to suggest it would be a tool from videohelp.com site ...
    it didn't run in a VM..
    do not download or try to run it.
  8. I'm a MEGA Super Moderator Baldrick's Avatar
    I have removed all links to that program. I have not created it. Lafamar banned.
    Jul 2017
    North Pole
    Hi...
    You can download that video with pyIDM, the app is open-source (github) and uses youtube-dl + ffmpeg plus other tools to download videos..
    the author of pyIDM just started a topic on this forum ...
    See the topic HERE.
    it is portable,no installation needed...
    paste the following URL into pyIDM and choose the quality of the video (your internet connection has to be in the u.s. or you can not stream/download it)
    if my url paste does not work for you, get Video Download Helper add-on for firefox,to get the m3u8 master file url information, which you then paste into pyIDM's address line.
    https://tveoxygen-vh.akamaihd.net/i/prod/video/87/251/200331_4142127_Kim_Kardashian_West__The_Justice_Project_,25,40,18,12,7,4,2,00.mp4.csmil/master.m3u8
  10. @Baldrick
    well done! that guy offered his tool everywhere and without providing information on what it was...
    and it was certainly not a regular thing, otherwise he would have provided explanations on what it was (info requested several times)
    thanks for your intervention!
  11. Thanks everyone for your help and spotting the untrusted links!
