    Jan 2013
    Under the Boardwalk, AC, NJ
    I bought a 1000x USB microscope off of eBay and have lost the install/driver/app disc that came with it.
    Does anyone have the necessary SW (or a download link) for this microscope camera?
    hxxps://www.ebay.com/itm/132137624725?ssPageName=STRK:MEBIDX:IT&fromMakeTra ck=true
    Thanks in advance
    Apr 2003
    I do not have this device but I did do a few Google searches. None of my searches mentioned a driver disc.
    Try this site:
    https://www.jiusion.com/art/usb-microscope-driver-downloads-a0044.html
    Aug 2004
    PA USA
    The only thing I can tell is it looks like a MicroTroniX microscope, I had no luck finding software for it.
    It's not important the problem be solved, only that the blame for the mistake is assigned correctly
    Dec 2005
    Canada
    Not sure, but if the device is shows up in the Device Manager, it's properties would show the hardware id's, then that would be searchable on line.
    Jan 2007
    Republic of Texas
    Download and install the software "Smart Camera" from www.inskam.com/download/camera.zip
    or download "ViewPlayCap" from www.inskam.com/download/PC.zip
    Connect the device with computer, light is on, then run the "Smart Camera."
    Switch to and select the camera "inskam3XX" in the APP by clicking on the devicce option in Setting, then use it.
