  1. I only have to put AVISource("myfile") in AVSPMOD or AVSMETER and they crash. This is the type of AVI file I will be getting from a film transfer house except at 16fps for 8mm film. I am able to open the file in Vdub, Premiere Pro and other programs, VLC does not play it correctly maybe it's one frame at a time. I uploaded a small clip but I don't know where it went. I get no error messages and don't know how to find out the problem. I was hoping to use these file types as I have been told they are very lossless. If that is incorrect please let me know before I summit my film. If I'm missing a codec I don't know how to find it either. I've tried a bunch. Thank for all of your time.
    Complete name : C:\Users\ME\Desktop\testvideofiles\Sample1.avi
    Format : AVI
    Format profile : OpenDML
    File size : 4.50 GiB
    Duration : 24 s 316 ms
    Overall bit rate : 1 589 Mb/s
    TCOD : 36462259166
    Format : YUV
    Codec ID : v210
    Codec ID/Hint : AJA Video Systems Xena
    Bit rate : 1 588 Mb/s
    Width : 2 048 pixels
    Height : 1 504 pixels
    Display aspect ratio : 4:3
    Frame rate : 23.976 (24000/1001) FPS
    Color space : YUV
    Chroma subsampling : 4:2:2
    Bit depth : 10 bits
    Compression mode : Lossless
    Bits/(Pixel*Frame) : 21.500
    Time code of first frame : 01:00:42:14 / 01:00:42:14
    Time code source : Adobe tc_A / Adobe tc_O
    Stream size : 4.49 GiB (100%)
  2. AVISource requires a VFW decoder for v210, such as AJA, Blackmagic, drastic codecs .
    You can use lsmash or ffms2 instead .This is what I would use, because on Windows, some of those codecs return RGB converted
    FFVideoSource("C:\Users\ME\Desktop\testvideofiles\ Sample1.avi")
    or
    https://github.com/HolyWu/L-SMASH-Works
    LWLibavVideoSource("C:\Users\ME\Desktop\testvideof iles\Sample1.avi")
    Mar 2008
    LAV filters has a directshow filter for it, then instead of Avisource("myfile")
    you can use directshowsource("myfile"), or DSS2("myfile") (supposed to have better frame accuracy than directshowsource)
    For DSS2 you need avss_26.dll in your Avisynth 32 bit plugin library
  4. Originally Posted by poisondeathray;2578483
    [url
    https://github.com/HolyWu/L-SMASH-Works[/url]
    For some reason this Lsmash version is returning some duplicate frames and weird issues when seeking. This Lsmash branch is usually very reliable, and v210 is just uncompressed 10bit 4:2:2 - it's pretty standard.
    FFMS2 decodes it correctly, but has a duplicate at the beginning and near the end. I believe they are there in the file, because vdub2, other programs show them as well
    There should be no duplicates in a film scan, what was process used?
    EDIT: Threads=1 seems to help the seeking for lsmash
  5. Installed the LAV filters and got it to work with the
    and
    still won't work with
    AVISource("C:\Users\ME\Desktop\testvideofiles\ Sample1.avi")
    Not sure what process they use, Cinepost is the company. Now I'll check on the rest of video restoration plugins and see how well I can make that work. This is all a very steep learning curve. Thanks for the help. Ill check back in when I have my next one hundred problems.
