Now that mkvmerge no longer supports cutting and joining of FLAC audio streams, a feature the creator says never worked right all along, I am in need of a substitute for that functionality.
From browsing this forum, I know several encoders are capable of cutting video files without reencoding them, like mkvmerge does. I don't know if they actually use mkvmerge to do that though. Those that do would lose the ability to cut FLAC when they update their mkvmerge.
More important is joining. I don't know of any other application that can join videos like mkvmerge does.
Another approach would be to convert the FLAC into a format that mkvmerge can work with. But which has similar settings to FLAC? 16/24 bit depth, 48kHz sampling, multiple channels. More importantly, which app lets you set all that?
in 30 years as an independent video editor i've never once been given anything with flac as the audio. and i've been sent some weird shit. if i were you i'd demux, convert to wav, mux it back together and go from there. flac isn't an audio format that belongs in video.
Flac is used in some videos so it's ok to ask in this forum.
"Programmers are human-shaped machines that transform alcohol into bugs."
Audio channel mapping for BluRay audio to FLAC using eac3to
By calvinpn in forum AudioReplies: 3Last Post: 31st Jan 2020, 06:49 -
Stripping audio off music video and using FLAC as audio instead?
By SE14man in forum Newbie / General discussionsReplies: 9Last Post: 27th Jun 2019, 10:07 -
FFmpeg cutting/joining findings
By Budman1 in forum EditingReplies: 4Last Post: 11th Jul 2018, 01:25 -
Any VideoPad alternative suggestions for cutting/joining? (Willing to pay)
By sincostan45 in forum EditingReplies: 0Last Post: 6th Jun 2017, 00:25 -
Bluray Audio to FLAC
By ultradj83 in forum AudioReplies: 12Last Post: 22nd May 2016, 14:33
