I just updated from v 43. First, the update fails on the GUI file and I had to uninstall, reboot and delete the file, then install the new version. That was really annoying. When I run it the GUI is larger than my screen resolution and I have to scroll down to see the "Add File", etc, where the previous version fit on my screen (1920 x 1080) . That's the max I can do and I wouldn't want a higher resolution because it would be too difficult to read. I couldn't find a setting for the GUI to fit to screen size. Any ideas?
I have just replaced v. 40.0.0.14 with the most recent one (v. 45.0.0.1) and haven't found the issue that you described
FWIW: my OS is Windows 7 64-bits, I don't use MKVtoolnix's installer, I never let the application update itself automagically and I always use the file mkvtoolnix-gui.ini so that MKVtoolnix never messes with the Windows registry
"Programmers are human-shaped machines that transform alcohol into bugs." -
I'm using Windows 7 Pro 64 bit.
I went back to V 43, I played around with V 45 and it didn't instill a lot of confidence. -
You can change display properties in Preferences (Ctrl+P), and then in GUI: font size, and scaling for high DPI.
I noticed the GUI stays active in the process task list after you close it. This is why I had difficulty with the update install.
You can't kill the process.
I'll try v 45 again soon, I think the default font size is set too large (13). where V 43 is (9).
Oh well...
about MKVToolNix
By ujang in forum Newbie / General discussionsReplies: 8Last Post: 16th Nov 2018, 22:32 -
MKVToolNix Help!
By Alekos65 in forum Newbie / General discussionsReplies: 6Last Post: 12th Jul 2017, 00:26 -
MKVToolNix
By ThomasCSR in forum Video ConversionReplies: 6Last Post: 14th Jun 2017, 11:19 -
Windows Update won't update
By joecass in forum ComputerReplies: 49Last Post: 31st Jan 2017, 04:38 -
Need help using MKVtoolnix
By Larold in forum SubtitleReplies: 8Last Post: 6th Apr 2016, 07:00
