I have a dumb question: is there a way to make VCD with two audio tracks? Stereo is preferrable but mono is also OK.
When playing with a DVD player, I should be able to use the AUDIO button to select the audio track (1 or 2).
If yes, what are the recommended procedure and tools?
I've heard rumors that you can make selectable subtitles (up to 4 tracks) and audio (2 tracks, AC3) SVCD. But I've never been able to find anything on it.
The first thing that comes to mind thou (if mono is ok) is to make a wave file with different audio for the left and right tracks, then only play one (option on most TVs I've seen). Not sure if that helps
I had a similar question (except for SVCD). Have a look at my link:
http://www.vcdhelp.com/phpBB/viewtopic.php?topic=52517&forum=1&4
For VCD, as part of its specs, you can have 1 stereo or 2 mono soundtracks. Check out:
http://www.vcdhelp.com/svcd.htm
For the specs of VCD vs SVCD
Graham
I had that same question. I made a vcd with two audio tracks one left channel and one right, it worked brilliantly, but both channels are mono and the sound is quiet low but here's a link and see if that helps.
http://www.vcdhelp.com/phpBB/viewtopic.php?topic=39888&forum=3 -
VCDs only support stereo audio track. Obviously, this can be one stereo (L and R) or two mono (L OR R) tracks.
SVCDs can support a couple (?two) of stereo soundtracks. This is in MPEG-audio NOT AC3 (digital Dolby).
Regards.
Michael Tam
w: Morsels of Evidence -
hmmm,
This is getting interresting
I have no clue if it is an official standard and if any DVD/VCD players detect and use such discs, but I-Author is able to create Karaoke VCDs.
I do know that these have 2 combined mono tracks. One with and one without voices. I haven't had the time to experiment with these, but it would be fun to do...
Further more I have one of those neat portable NAPA VCD players. With these you can switch the channels and spread them over both (Stereo) Speakers. Stereo would be L+R on both channels, but it can also put R+R or L+L on both channels
Greetz,
pSyChO dAd
The difference between genius and insanity is only measured by success ! -
I have tried SVCD with the Pioneer DV-333 and it allows to select one of the followings:
stereo, left, right, and two more I forgot what they are.
ktnwin - PATIENCE -
Standard VCDs support only ONE stereo track (which obviously also means you can have TWO mono tracks).
Standard SVCDs support TWO full stereo tracks (which means you can have two stereo tracks, four mono, or one stereo and two mono).
Regards.
Michael Tam
HOW do I extract 1 audio track from a .ts / .m2ts with 4 audio tracks?!
By elgy in forum DVB / IPTVReplies: 25Last Post: 23rd Jan 2011, 23:28 -
How to choose audio track in avi file with two audio tracks
By newnews in forum AudioReplies: 3Last Post: 26th Oct 2010, 05:26 -
Video with L/R tracks to DVD with 2 channel audio tracks
By Downloader in forum Authoring (DVD)Replies: 2Last Post: 22nd Aug 2010, 01:56 -
No Audio On AVCHD-DVD, How To Remove Other Audio Tracks From MKV File First
By elistian in forum Video ConversionReplies: 1Last Post: 14th Dec 2009, 06:03 -
--> Adding Audio CD Tracks to DVD audio ? <--
By MJPEG guy in forum Authoring (DVD)Replies: 0Last Post: 22nd Dec 2007, 16:45
