I'm having an odd issue I can't seem to workaround despite trying several hours to search various forum tips and softwares, etc. My initial problem was trying to combine a 4K disc back-up into one long M2TS file because they split the movie up into several of them, I cannot get Atmos when streaming from my PC using MKV but I can when I stream M2TS files so MKV works great for backing up movies with any version of dts including X, but "audio stream not recognized" when using Atmos-movies and so far seems to be no good option outside of buying an Oppo which aren't affordable. My Sony X800 doesn't recognize Atmos over MKV.
Anyway, I have 12TB storage so I try and back-up my most watched discs so they're easy to stream, this one has been bugging me because some movies have 10+ segments and it's annoying to watch a movie that way. There is a separate issue with TrueHD but I know I can try and rebuild it later on extracting that separately using the MPLS with ClownBD into a THD+ac3 file and remuxing, but this current issue I've definitely narrowed down to just TsMuxer.
The first segment of the new 4K disc of The Phantom Menace is 00055.m2ts, it plays perfectly when I stream just that file from USB stick. When I try and play the TsMuxer'd version, with no other conversions and/or with TrueHD removed, instead of a 2m02s video file I get a super choppy 1m47s file and the audio which plays fine is super out of sync by that amount (15s) just after 1m47 playing time. The video jumps every couple of seconds. I've looked at the mediainfo of the 00055.m2ts file before and after using TsMuxer (selecting frame=24/1001 or not doesn't seem to make a lick of difference) and I noticed something peculiar, the maximum peak bandwidth of the file that doesn't play properly is WAY lower than the original M2TS file. Any ideas?
File before conversion:
File after conversion with no changes (ie - TrueHD still included)General
Complete name : G:\Star Wars Ep1\Streams for joining\00055.m2ts
Format : BDAV
Format/Info : Blu-ray Video
File size : 757 MiB
Duration : 2 min 1 s
Overall bit rate : 52.2 Mb/s
Maximum Overall bit rate : 109 Mb/s
Video
Menu ID : 1 (0x1)
Format : HEVC
Format/Info : High Efficiency Video Coding
Format profile : Main 10@L5.1@High
HDR format : SMPTE ST 2086, HDR10 compatible
Codec ID : 36
Duration : 2 min 0 s
Bit rate : 46.8 Mb/s
Width : 3 840 pixels
Height : 2 160 pixels
Display aspect ratio : 16:9
Frame rate : 23.976 (24000/1001) FPS
Color space : YUV
Chroma subsampling : 4:2:0 (Type 2)
Bit depth : 10 bits
Bits/(Pixel*Frame) : 0.235
Stream size : 675 MiB (89%)
Writing library : ATEME Titan File 3.9.0 (4.9.0.0)
Color range : Limited
Color primaries : BT.2020
Transfer characteristics : PQ
Matrix coefficients : BT.2020 non-constant
Mastering display color primaries : BT.2020
Mastering display luminance : min: 0.0001 cd/m2, max: 1000 cd/m2
I've highlighted the differences. Thank you for any assistance, the goal here is to create a single M2TS file so I can stream using Atmos.General
Complete name : F:\BD Back Up UHD\Star Wars Episode I 4K\00055new.m2ts
Format : BDAV
File size : 757 MiB
Overall bit rate : 52.5 Mb/s
Maximum Overall bit rate : 35.5 Mb/s
Video
Menu ID : 1 (0x1)
Format : HEVC
Codec ID : 6
>>>>>>Duration : 1 min 47 s <<<<<<
Bit rate : 47.1 Mb/s
Color space : YUV
Bit depth : 10 bits
Bits/(Pixel*Frame) : 0.237
Stream size : 602 MiB (79%)
It almost seems like it's trying to mux everything to within a BD standard disc for BD25 or BD50, I don't see any options to stop this. I mean, losing 20s sync in just 2 mins, pretty big concern. Almost like watching an Eddie Murphy movie on network tv lol.
Can anyone advise if maybe I've posted this in the wrong area of the forum?
Might anyone suggest another forum altogether perhaps? Based on most other web search results, I had estimated if no-one here could help, I'm SOL.
TSMuxer 3D BR/AVCHD Not Splitting M2TS/MTS Files
By Mobe1969 in forum EditingReplies: 0Last Post: 6th Apr 2018, 21:41 -
MKVExtract give me a video file with 90000 frame rate in TSMuxer
By Animator811 in forum Video ConversionReplies: 5Last Post: 18th Oct 2017, 17:30 -
Apply color fill to a portion of video frame
By hand123 in forum EditingReplies: 22Last Post: 27th Feb 2017, 13:15 -
Batch convert TS to m2ts using tsMuxeR
By tangyue in forum Video ConversionReplies: 3Last Post: 3rd Feb 2017, 09:36 -
Repack mkv to m2ts with tsmuxer no sound
By shag00 in forum Video ConversionReplies: 4Last Post: 3rd Jul 2015, 16:45
