Recently I got a very small computer (minus the hdd) from an independent computer shop. They toss (recycle) them, & let me go through the 'pile'. I wanted the case for a (micro?) mobo I want to setup as exclusivly for watching dvds, (*.iso images), that have only CC's not subtitles. I have 'WinDVD' which shows CC's.
Anyways, this small comp is way too small for my (gigabyte a1m1) mobo. Before tossing it I put a "Mint" disk in & plugged in an old hdd. Got 'press any key to boot from cd: Pressed any key(!) & Win XP started up, all the way! I dont know which of my comps it came from. Got the new hardware need drivers etc. This lil comp happens to be an Intel Atom mobo computer. Found the very detailed pdf from intel & drivers DL page. Amazon sells this mobo for ± $180.00! The comp has heat resistant 2 gig ram, no cpu cooling fan, a 250 W psu. Comp has one PCI slot (full size). The original hdd was a WD 3.5" 0.55a @ 5v & 0.5a # 12 v.
Mine is a 2.5" 0.55a @ 5v. Movies would be on a WD 2.5 USB connection. Comp has a vga plug for monitor.
Is there a relativly cheap PCI -> hdmi card with XP drivers out there, I could use? VGA would be ok but hdmi would easily connect to my AVR (with 6 hdmi inputs). All I want it for is to watch movies with CC only. "My hearing is bad bad bad!"
-corne-
Yes, no, maybe, I don't know, Can you repeat the question?
Removing noisy lines in VHS captured DV video, perhaps with Atom Inspector
By celsoac in forum EditingReplies: 0Last Post: 27th Apr 2019, 08:55 -
Is there any way to detect if the MOOV atom is at the start of the video?
By ProxyCell in forum Video ConversionReplies: 4Last Post: 27th Feb 2018, 01:44 -
Atom Heart Mother Quad Blu-ray
By Dieu in forum Authoring (Blu-ray)Replies: 1Last Post: 27th May 2017, 14:50 -
Problems with restoring atom using recover_mp4_to_h264
By qtschk in forum Video ConversionReplies: 2Last Post: 19th Mar 2016, 11:30 -
Intel Skylake Review
By SameSelf in forum ComputerReplies: 0Last Post: 16th Mar 2016, 10:17
